What is the best Turbo for my Engine Set Up?
Old Jan 18, 2011 | 04:30 PM
  #31
jameswwt's Avatar
[quote=supersal;8998749]Haha, will look you up when next I'm in Malaysia...
Like the guys have said for the manifold you have a Stock Frame Turbo like and FP green will bolt on and meet your power goals...
But on your $1100 budget for a Ball Bearing, Water and Oil cooled Turbo I think the 50 Trim will give the best balance of power and spool for a T3 framed turbo...
GT3076R will spool later; GT3071R will spool much better than a 3076 but will be limited to about 450hp...
The Default T31 4 bolt outlet GT Style housing will do the job:
http://www.atpturbo.com/mm5/merchant...Category_Code=
I take it welding and fab work is more affordable over there like it is here in SA, you need:
T3 Flanged Manfold
Modify Downpipe for the T31 4bolt outlet
Dump Tube for your 38mm Wastegate
Antisurge Compressor cover not a bad idea if you can afford it
Only other option to retain your current manifold and get decent spool on a budget is to go with the 3071 with the much hated ATP style housing which bolts to stock manifold...
http://cgi.ebay.com/ebaymotors/GARRETT-EVO8-Turbo-EVO4-EVO9-GT3071R-GT3037S-GT3540R-_W0QQcmdZViewItemQQhashZitem587faafbbeQQitemZ38009 9034046QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries
ps. prepare to be flamed - guys on here will hate you for this - housing design is not great, cant match stock frame turbos for spool, only one that spools half decent is the: GT3071R _63AR but bang for the buck (ball bearing) it is...
regards
Sal
Thanks Sal,
last question is, will the Exhaust Manifold common to plug in this garrett T04E 50trim, GT3076R or GT3071R turbos able to fit or required much mod & will there be enough space.
Old Jan 18, 2011 | 05:15 PM
  #32
BenJ's Avatar
First, 380-450whp on what dyno; it will make a big difference. Second, this number can be achieved many different ways but nobody knows your opinion of lag better than yourself. Third, the suggestion; If you are going off of dyno jet numbers, a stock 9 turbo or FP HTA green will get you your numbers very easily and have the least amount of "lag". If you are basing your numbers off of a mustang dyno, then a FP HTA Green will be your answer (this is all on pump gas as well).
Old Jan 18, 2011 | 07:13 PM
  #33
evo8426's Avatar
i would think an fp red would accomplish the power goals the best without having to push the turbo to really high boost levels but still have decent spool
Old Jan 18, 2011 | 08:16 PM
  #34
jameswwt's Avatar
Just wonder how abt a GT35R??? Since its a ball bearing but will it still very laggy base on my set up?
I know a guy here is selling of his GT35R...
Old Jan 18, 2011 | 11:17 PM
  #35
supersal's Avatar
Originally Posted by jameswwt
Thanks Sal,
ETS Super Value T3 Manifold ; we have run these and they work great...
Old Jan 18, 2011 | 11:25 PM
  #36
supersal's Avatar
Each person has their own idea of what is acceptable lag for them, If you dont mind the lag, have a look at some of the stock block 35r Dyno Sheets and ask the guys with those set-ups about driving experiance...
I have a AMS HTA30R on a stock Block and I love it - its a blast to drive, dont care if guys here think I will be beat by stock frame turbos, I just like the way it pulls to redline even on low boost...
Hope that helps.
regards
Sal
Old Jan 19, 2011 | 04:23 AM
  #37
SmurfZilla's Avatar
Fastest response and minimal lag......HKS GT II 7460. Made my BBK Full feel like a laggy turbo. I made over 450 on a dynojet with it.
Old Jan 19, 2011 | 08:16 AM
  #38
jameswwt's Avatar
Thanks Guys...
Old Mar 27, 2011 | 10:46 PM
  #39
jameswwt's Avatar
Ok guys,
ive now limit down to 3 turbos best for my goal, please do help to decide which is best for my set-up :
1) Garrett Ball Bearing T3/T4E 50 / 57 Trim Compressor (ATP)?
2) Garrett GT3071R Turbo Ball Bearing Turbo?
3) Bulleye S256 Non ETT or with ETT Journal Bearing type?
Thanks
Old Apr 2, 2011 | 03:15 AM
  #40
boonkae's Avatar
James ...
Just go for the GTX3076R ...
Get it from either Klone Turbo or Tong Turbo ...
Old Apr 4, 2011 | 08:17 AM
  #41
jameswwt's Avatar
Originally Posted by boonkae
James ...
Hi Boonkae,
do i know you? You look familiar...hahahahaha
Ive opt for GT30R...As GTX version is way exceed my budget...
Old May 3, 2011 | 06:35 PM
  #42
Silvermike's Avatar
has there been any testing of the gtx3076 yet? like solid dyno numbers?
Old May 4, 2011 | 06:10 AM
  #43
stabiemcstabin's Avatar
also interested in the gtx3076 but is any body run this with good results, I'm wanting a ball bearing turbo on the grounds of them lasting longer then journals.
Old May 4, 2011 | 06:25 AM
  #44
jameswwt's Avatar
Latest Update : Im installing my turbo and within early next week will go for a re-tune and will post my dyno graph for reference.
Oct 18, 2016 12:43 PM
nsheasley
May 2, 2016 09:17 AM
jameswwt
Oct 12, 2010 07:11 PM
jameswwt
12
Sep 20, 2010 10:11 AM
Oracle1
Mar 30, 2008 09:57 PM
