Throttle cable sticking?
Old Jan 27, 2011 | 10:38 AM
EVOMIZ's Avatar
I have been having problems with the throttle hanging and sometimes it feels like its stuck when shifting. Where can i buy a new cable.
thanks
Old Jan 27, 2011 | 10:49 AM
metalsaber's Avatar
You mean other than a Mitsubishi Dealership?
Old Jan 27, 2011 | 10:53 AM
achilles3000's Avatar
thanks
Check your tune,and check to see of your throttle body shaft seals are leaking mine did this when they were bad...If this all check out fine buy a new throttle cable from the dealer .
Old Jan 27, 2011 | 12:03 PM
06RedRalli's Avatar
Yes, def check the throttle shaft seals first...prob the reason...order some mil spec ones...
Old Jan 27, 2011 | 12:05 PM
Smike's Avatar
Check for carbon build up on the butterfly. Take TB off. Remove sensors. Clean with brake cleaner.
Old Jan 27, 2011 | 12:09 PM
EVOMIZ's Avatar
thanks i will check the seals.
tune should be fine .
but where else besides the dealer can i get the cable
Old Jan 27, 2011 | 12:13 PM
metalsaber's Avatar
Send an PM to RusselM.
Old Jan 27, 2011 | 12:16 PM
06RedRalli's Avatar
Just found one on ebay...pretty cheap too...
http://cgi.ebay.com/ebaymotors/03-06...Q5fAccessories
Old Jan 27, 2011 | 12:55 PM
EVOMIZ's Avatar
Thanks I will keep an eye on it
Old Jan 27, 2011 | 12:57 PM
05blue8's Avatar
Are you sure it's really hardware related and it is actually hanging?
Keep in mind Evo's have issues with throttle hang, just search and you'll see. There are alot of people trying to cure the tune side of it who all of a sudden develop it.
Throttle
For Sale - Miscellaneous Automotive
Mar 25, 2016 07:23 PM
Thahomeboyb
Lancer Engine Tech
Jun 14, 2014 06:43 AM
smoOVE
Feb 17, 2013 06:49 AM
Ralliartize It
Oct 27, 2011 02:00 PM
Ralliartize It
Aug 29, 2011 03:06 AM
