whining sound on the move.....Help
Old Jan 28, 2011 | 04:49 PM
evo7vii's Avatar
Dear Evom,
My car started to develop a very weird whining sound. That happens while cruising, accelerating and sometime just rolling. The sound is independent of any gear and is consistent in loudness. Even with the clutch pressed, or out of gear, its there and it only stops when the car is about to come to a halt.
the sound is coming from the left front end of the car and cant determine the actual source due to the fact it only appears while moving at higher speeds and stays afterwards even of am just rolling while off the gas peddle, and again it goes away just before the car comes to a halt.
what also is driving me crazy is that i drove during the day and nth was there. then i went out after it started raining and it started to happen. Moreover, the sound is not always present, and when its there and i go on a rough surface it goes away.
I know it seems weird as i check every possible thing in the engine bay with no luck of find sth loose or out of order.
really appreciate the help guys
Old Jan 28, 2011 | 04:57 PM
evo unknown's Avatar
Search youtube for 'transfer case death whine'.
That is the first thing that pops into my head with your symptoms. I do not mean to scare you if I am incorrect, but compare the youtube videos to what you are experiencing.
Old Jan 28, 2011 | 05:31 PM
evo7vii's Avatar
well i did that and mine seems different as its not as load and doesnt go louder at higher speed it just stays at the same sound level. Also if i go over a dip in the road it goes away.
Old Jan 28, 2011 | 05:42 PM
evo7vii's Avatar
Also guys let me clear one things the sound is not always there i stop the car and start driving again with no sounds.
When it starts it starts after am already on the move and going higher in the speed but not just when i starts moving it. like i put it in 1st and go (no sound) 2nd (nth) 3rd it starts to make the sound (not always though) but when it starts it stays until the car is almost at a halt or even barely moving.
Old Jan 28, 2011 | 05:55 PM
Frank120's Avatar
my car makes a faint whine, but thats when im crusing in 4th. but it goes away when i let go of gas. i would bring it to the closest shop that knows stuff about evos and or dsms good luck
Old Jan 29, 2011 | 02:01 AM
evo7vii's Avatar
Guys any input would be really appreciated. The had all fluids
Flushed 1.5k kms ago. Also I check the rear ACD oil tank and
Oil is at the min level just after I park the car.
Old Jan 29, 2011 | 11:10 AM
evo7vii's Avatar
An update
Today took the car out and the sound is gone?! I only have the
Normal 1st and 2nd whine that am used to.....
I checked the car for any leaks and its dry and I also check the
Acd tank before going out and it was at max. Level.
What can that sound be?! And does the fact that it started to
Come out after it rained indecat anything?! Please guys any
Inpute would really help. Thanks
Old Jan 29, 2011 | 04:26 PM
Berts24's Avatar
is there a certain speed that is seems to be the loudest??
Old Jan 29, 2011 | 04:50 PM
evo7vii's Avatar
nopes it really consistent in level. it wont go louder when i speed up, change gears, roll, press clutch or anything it just comes and stays on the same exact level until i really slow down.
JrEvoXnitez
Jan 11, 2017 08:46 AM
Brkesar
Feb 20, 2015 08:04 AM
EMonz57
Apr 22, 2014 09:03 PM
Ramonski
49
Dec 7, 2011 02:49 PM
svt_lightning01
Aug 10, 2011 10:07 PM
