Exedy Twin Hyper HD or SD ?
Old Feb 7, 2011 | 05:55 AM
evo9_jdm's Avatar
Hello,
I just put in a new stage 2 sheptrans transmission, 4 pack clutch Exedy stage 2 ceramic and new PTE6265 from AMS GT900X. In Evoscan I was hitting 2byte loads 260 and now with the new turbo at 27psi I am hitting 345 loads now with my new stage 2 ceramic at 7000 to 8000rpm I can't put the gears in and I contacted John at sheptrans and he said this is a common thing he told me to install a twin plate and I was going to install Exedy but there is the HD and SD I think I should use the HD I should hit the 10 sec 1/4 with this so an SD is for more light power HP.
Any advice will help thanks mates ?
Old Feb 7, 2011 | 06:03 AM
PKEVO8's Avatar
SD is more of a street application, HD is for racing; Thus, if you are drag racing, get the HD pressure plate
Old Feb 7, 2011 | 06:19 AM
shh!! sleeping's Avatar
Get the HD.... i use it daily driving as well.
Old Feb 7, 2011 | 01:48 PM
evo9_jdm's Avatar
HD sounds good then hope it will last a bit what I have herd they don't last long
Old Feb 7, 2011 | 01:59 PM
JDMevoBOOST's Avatar
You can get 30K out of it if you aren't abusing it too heavily. And the great thing about them is they are rebuildable.
Old Feb 7, 2011 | 07:13 PM
justboosted02's Avatar
mine is going strong at 20k miles
Old Feb 8, 2011 | 03:25 AM
evo9_jdm's Avatar
Ok I will buy the HD next week how many mils should I do for brake in ?
Old Feb 8, 2011 | 07:31 PM
JohnBradley's Avatar
200 or so is all it really seems to take. The SD should actually NEVER be an option. There is absolutely no reason to buy it. If someone is worried about pedal feel and is thinking the SD is the answer they dont need a twin, period.
Old Feb 9, 2011 | 05:42 AM
5LEEPERISAH23I's Avatar
spend the extrea $100 dollors you will not regret it, seems like your going to the drag to run a 10 or attempt too
Old Feb 9, 2011 | 05:55 AM
dieselmd's Avatar
Just a thought here but that's a big turbo. If you have plans on running some type of racefuel, that twin hd will not hold the power that turbo is capable of making. You'll need a triple for that.
STLEVOIX
May 27, 2016 09:24 AM
Aby@MIL.SPEC
May 18, 2016 05:39 PM
fromWRXtoEVO
32
Nov 22, 2010 08:43 AM
b16a95eg
Jul 6, 2010 05:28 AM
blackblaze427
18
Mar 10, 2009 07:31 PM
