Engine Removal
Old Feb 16, 2011 | 02:54 PM
widge's Avatar
Engine Removal
Hey Guys,
Motor is coming out over the weekend was wondering if you can remove the motor and leave the Gearbox in the car?
Cheers
Old Feb 16, 2011 | 04:29 PM
evoballer's Avatar
No you cant, you have to drop the motor, tyranny and front suspension all in one. You can leave the center and rear diffs in the car tho.
Old Feb 16, 2011 | 04:36 PM
wizzo 8's Avatar
If you don't have a lift you can unbolt tcase and pull motor with trans from top.
Old Feb 16, 2011 | 04:45 PM
widge's Avatar
I dont have a lift but where pulling the head off with the motor in the car so i think the rest of the motor GB will slide out from the bottom.
Cheers guys
Old Feb 16, 2011 | 04:56 PM
EvoLutionized8's Avatar
definitely use a lift if possible. easiest way is to take out TC, leave trans on, complete log block and drop it all. lift car outta the way and viola.... GL!!
Old Feb 20, 2011 | 01:54 PM
widge's Avatar
Ok guys,
Got the motor out, Piston 4 has a chuck take from the side of it, so this was either caused by my new PTE injectors im getting them flow tested or when the Vacuum line blew off the FPR causing the car to run Lean 1 time...
Some Pics
Oh and thats the motor out with the gearbox in the car you can do it..
Cheers
Old Feb 20, 2011 | 04:57 PM
wizzo 8's Avatar
So you took the head off before removing the motor? If so what points did you use to lift the block out?
Old Feb 20, 2011 | 05:32 PM
LCS's Avatar
LCS
I´ve taken the block from under the car, without the head. Perhaps he did the same thing.
Old Feb 20, 2011 | 06:44 PM
widge's Avatar
Yeh Head off, then removed the block from under the car
Old Feb 21, 2011 | 12:31 AM
My03evo's Avatar
I know you already got the motor out but for people doing a search or subscribed here's some more info on a thread I made
https://www.evolutionm.net/forums/ev...-head-off.html
17579EVO9MR
May 30, 2016 12:07 PM
Evo_Jr
Apr 16, 2011 11:03 AM
twinturbozs
Jul 5, 2010 03:10 PM
fishie36
Mar 15, 2010 02:06 PM
insanechief
25
Jul 28, 2008 06:47 PM
