Throttle body shaft seals and proper plate sealing
Old May 24, 2011 | 06:04 PM
vmrevo9's Avatar
Veteran: Air Force
Originally Posted by bruce988jl
Just ordered two cans of molykote (All my friends are having idle ranging issues not being fixed by the IAC sensor) for 28$ a pop shipped (ironically from a warehouse in cali) I'll give it a shot and get back at you guys.
OP - thanks a ton I have been trying to figure out why my idle has been dropping ever since i bought the car. I have already replaced 2 iac sensors hoping to fix it with no luck...
any luck??
OP what size filler gauges did you use to center the plate? i need to replace one of my screws as it is in bad shape.
Old May 25, 2011 | 06:58 AM
krazykorean84's Avatar
Originally Posted by Liqquid
No luck at the Mitsu dealer?
Haven't gone to the dealer to acquire throttle plate screw but I was hoping someone here had experience finding and replacing them.
Old May 25, 2011 | 11:42 AM
TheBoz's Avatar
For the screws I just went to a hardware store out here that carries all sorts of screwes in metric and standard, looks for the ones that matched and picked up a hand full of them. They are like .01 each.
Old May 25, 2011 | 08:29 PM
Evoryder's Avatar
This will be my next task.
Old May 25, 2011 | 09:03 PM
rush63's Avatar
Just wondering if vendors who do throttle body porting also use films on their finished products? I'd appreciate it if people who's got their throttle bodies ported would chime in regarding this.
Old May 25, 2011 | 09:58 PM
Evoryder's Avatar
I have the Buschur 65mm and it did not the film that i could see.
Old May 26, 2011 | 05:42 AM
rush63's Avatar
Evoryder, are you seeing a gap between the TB and the plate like in the the picture below or did David Buschur use a plate big enough that the use of dry film is no longer needed? If it does have a gap, are you having stalling issues?
Old May 26, 2011 | 08:28 AM
rush63's Avatar
Originally Posted by Aby@MIL.SPEC
great write-up!
Do you use dry film on your rebuilt or ported TB's?
Old May 26, 2011 | 10:54 AM
Evoryder's Avatar
i don't think the gap is bad at all...not like the stock cleaned up valve. i definitely remember seeing the same gap on my stock tb. Buschur uses a different plate i believe. If i pick up the stuff today i'll take a pic of my DB TB before and after.
I don't have stall issues, I'm trying to clean up my slow speed take off driveability.
Old Jun 25, 2011 | 05:17 PM
hyeteck's Avatar
a buddy of mine was able to pick up a can of dow corning molycote 321 for me with his business license (http://www.grainger.com/Grainger/DOW...ubricant-6Y773)
I actually have my throttle body off and just sprayed the second coat. I'll let you guys know if there is any improvement in drivability. I've been having stalling issues while depressing the clutch as i come to a stop. I've also been having throttle hang issues with the car feeling as if it were in cruise control on the highway.
Old Jun 26, 2011 | 03:43 PM
hyeteck's Avatar
This kind of fixed my stalling issues. The throttle hang is still there though.
I had to open up the biss a little after putting the throttle body back on so the car would idle properly. I remember when I "cleaned" the TB, i had to close the biss because it was idling to high.
Old Jun 26, 2011 | 03:55 PM
evo8426's Avatar
I cleaned all the gunk off the back of mine without thinking it was there for a reason. I did not use a feeler gauge when reinstalling but have not had any stalling issues whatsoever
Old Aug 26, 2011 | 08:36 AM
boostedwrx's Avatar
I picked up some dry moly lube from Grainger today (the 842 that Liquid got). I'll see how this goes. My WORKS throttle body doesn't have too bad of spacing but it can still be improved.
Thats what I'm expierencing... the throttle wants to hang during shifts and what not. I'm 99% its the throttle cable though. The routing with the Magnus isn't the best and the more I play with it the less throttle hang I have.
Old Aug 26, 2011 | 12:53 PM
Aby@MIL.SPEC's Avatar
yes, for several years now.
Old Aug 26, 2011 | 01:15 PM
boostedwrx's Avatar
I can guarantee Aby has been doing this for years, I remember seeing one first hand and was wondering what the stuff was Makes perfect since and they have been doing it all along.
Just waiting for the coats to dry on mine..
