Rebuilding Transmission?
Old Feb 22, 2011 | 10:45 PM
ch1215g's Avatar
SUSPECTED SCAMMER
So some of you might know that i recently blew my 5th gear synchro and now my transmission is acing up. I have a shop that i can go to local and were gunna tear out the trans and look at it, im planning on rebuilding everything that looks like it needs to be built... to get to the point, Sheptrans, TRE, Buschur ETC... all offer there "built" transmission for the evo 8/9/10 im wondering if i could put different internals in my transmission to be able to support the power im making, at a lot less of the cost. (500 whp 400 wtq) Time is an issue also thats why i cant send it out to any of them until probably next year.
The other option would be just to rebuild the transmission and not have it "built" would the 5 speed handle that power for a good 30k miles lets say?
Old Feb 22, 2011 | 10:47 PM
Pal215's Avatar
the stock 5 speed should handle that much power forever as long as you keep up with maintenance and don't launch it often. But if i were in your shoes id just get it built and be done with it!
Old Feb 22, 2011 | 10:58 PM
ch1215g's Avatar
SUSPECTED SCAMMER
i would it built but i dont have 900+ to spend right now i have about 200 i just need parts labor isnt the issue, does anyone know where i can get the parts i need for super cheap?
thanks for the quick response !
Old Feb 23, 2011 | 04:36 AM
ch1215g's Avatar
SUSPECTED SCAMMER
bump
Old Feb 23, 2011 | 06:27 AM
Jrah2987's Avatar
Veteran: Air Force
The only place I know that would sell individual parts like that is TRE, but for $200 I'm not sure you're going to be getting very much out of it.
Good luck.
Old Feb 23, 2011 | 08:03 AM
EvoJoeIX's Avatar
The actual gears in a stock 5 speed can handle all the power you can throw at them. All you would need to do is throw in new syncros and stuff. Thats basically all the shops do anyway, but they arent just factory syncros and they do their tricks to get them to shift better
Evo parts and cheap dont go together. Do it right and save your pennies and have a shop do it.
Old Feb 23, 2011 | 08:07 AM
06evokid's Avatar
Stock 5 speed trans
ch1215g's Avatar
SUSPECTED SCAMMER
Yeah im going to be changing 5th gear synchro and whatever else needs to be changed.
Old Feb 23, 2011 | 05:37 PM
chaotichoax's Avatar
I'd go to dog box racing in Howell for any tranny needs
many high hp evo's have relied on the stock 5 speed tranny
Old Feb 23, 2011 | 08:31 PM
lillev23's Avatar
I rebuilt my trans at home with a hydraulic press and a couple of hand tools. Synchros are very easy to replace. Just get a copy of the evo manual, and you should be able to knock it out in a weekend. You can get a nice rebuild kit from TRE with everything you will need for about $600.
delcster27
11
Mar 29, 2017 03:05 PM
jason42003
Apr 30, 2012 07:54 PM
denver
May 11, 2009 07:59 AM
xpehbam
Northeast Region
Nov 10, 2007 06:45 AM
