Debating on changing my cams...
Old Mar 3, 2011 | 06:06 AM
partyboy1122's Avatar
On the fence as if I should swap out my cams this year or not.
Specs on my car:
Stock block/head (Even stock head bolts, arps going in soon)
Stock Ecu (Self tuned)
HKS 280s
AMS 35R
4"FMIC
3" QTP Cut out
All other supporting mods.
I run strictly 93 octane in my car. 32-33psi daily.
Multiple drag runs. Best time up to date 11.28 @ 127mph 1.8 60'
I have been trying to get my 10s pass, but my launching skills have not been that great I shall admit.
I was going to upgrade the turbo to an HTA86 this year or may even stick to the 35r. I also plan on porting my intake manifold.
I don't mind the mild 280s in the car right now, it was great on all my previous turbo setups from, stock 8 turbo, IX ported, 3065, etc.
I was debating wether I should look into FINALLY upgrading such mild cams to something more aggressive.
What do you guys think? Just trying to get some ideas.
Old Mar 3, 2011 | 06:10 AM
escodotcarter's Avatar
you should have already but i would get some headwork done, at least upgrade the valvetrain. I can only imagine what you are revving that up to.
Old Mar 3, 2011 | 06:18 AM
I plan on breaking into the 10s with stock block/stock head. Once that goal is achieved I will be even planning a motor build for next winter. I am revving the motor to 8200.
Old Mar 3, 2011 | 08:19 AM
wow, luck must be on your side.
Old Mar 3, 2011 | 08:28 AM
JohnBradley's Avatar
At that level with that turbo, S3s will work nicely. Here is a set doing work on a stock block w/ Black-
http://www.youtube.com/watch?v=mTOTgAhS-Q8
Old Mar 3, 2011 | 09:11 AM
I don't see how it's luck? Have owned the car for over 3 years, no issues?
I also have a few customers running similar setups on completely stock block/head going low 11s at the track. A lot has to do with the tune!
John, thanks what is the lift on these cams? I'm assuming valvetrain upgrade is a must?
Old Mar 3, 2011 | 10:04 AM
tscompusa2's Avatar
http://www.power-division.com/home.php?cat=279
id do s3 on hta86 also.. id like to swap my kelford for the s2 also but im to lazy.
all the new gsc grinds are way better then most cams out.
Old Mar 3, 2011 | 10:06 AM
I was thinking about switching to the s2s. It's gonna be an adventure to see how far the stock block will hold if I replace the 35r with the HTA86.
I don't plan on running the same boost levels, perhaps 25-28psi on pump.
chaotichoax
Apr 12, 2020 11:55 PM
fortyPSIrs
Sep 28, 2011 04:30 AM
Ludikraut
Jun 14, 2009 06:11 PM
RUN FOREST RUN
18
Jun 16, 2008 06:33 PM
Blue Evo 8
19
Jul 22, 2005 09:14 AM
