Valve cover gasket
Old Mar 5, 2011 | 06:09 PM
sleepy_rps13's Avatar
Valve cover gasket
My valve cover gasket was leaking so I had it replaced with a brand new OEM one. It was fine for about 3 months then it started leaking oil again. Is this a common problem for our cars? Or is there a certain procedure we have to follow? Maybe retightening the bolts after a certain amount of time? I followed the procedure in the manual along wig proper torque specs and tightening order. Thanks
Old Mar 5, 2011 | 06:19 PM
sho669's Avatar
Mine would loosen up after a while, I retightened them three times or so in 7k miles. I run the three AMS poly bushings though it would start to leak a little and i'd just snug them up, leak gone.
Old Mar 5, 2011 | 08:35 PM
4RETECH's Avatar
Sorry to say I've never had mine leak. I don't think it's a common problem.
Old Mar 5, 2011 | 08:39 PM
evo9ben's Avatar
same here never had a leak.
Old Mar 6, 2011 | 06:37 AM
barneyb's Avatar
When you say OEM do you mean it came from Mitsubishi? The reason I ask is that the gasket style hasn't changed over the years but the old ones used to leak. Apparently, there has been a change made to the material they are made out of. Also, did you use RTV in the corners like the manual instructs? And, yeah, it is a good idea to bring the bolts back to torque after a few thousand miles.
I'm surprised you are having this problem. It might be that your valve cover is cracked.
Old Mar 7, 2011 | 02:59 AM
Yes, it is genuine mitsubishi valve cover gasket and I did use RTV where the manual instructs. The weird thing is that it was fine for about 3 months. Then, it started leaking again. I've inspected hte valve cover several times for cracks but found nothing. hopefully, it's not some hairline cracks... Thanks for all the replies!!!
mar387
Jan 4, 2017 04:23 AM
Wanted EVO IX
Sep 2, 2016 06:30 AM
Samd531
May 20, 2012 11:25 AM
4DOORGALLOR
May 31, 2010 06:39 AM
Lumpy
20
Dec 18, 2007 02:19 PM
