Hesitation when warming up
Old Mar 8, 2011 | 09:57 PM
McDougal's Avatar
Not sure if this is a common problem or not, but my car seems to hesitate during the first few minutes of driving immediately after starting it. If I push the pedal harder the car accelerates really slowly and sounds like it's under heavy load. Almost seems like it isn't getting enough fuel or something. Does this happen to anyone else?
Old Mar 8, 2011 | 09:59 PM
BLK_EvIL's Avatar
if im not mistaken the ecu pulls alot of timing when your car isnt fully warmed
Old Mar 8, 2011 | 10:12 PM
BluEVOIX's Avatar
Yes happens to me as well. And the car bucks and jerks like its on/off throttle. I dont know why it happens though.
Old Mar 8, 2011 | 10:14 PM
06RedRalli's Avatar
Yes, common...mine def does the same thing...haven't really had time to mess around with trying to tune it out if possible...im sure there's a way.
Old Mar 9, 2011 | 08:51 AM
barneyb's Avatar
Yeah, I'd chime in an also say that's normal with the factory tune. If it is still doing it after more than a mile of driving then maybe something is wrong.
Old Mar 9, 2011 | 09:01 AM
4wdrifter's Avatar
It's because the turbo isn't warmed up. Mine has always done this. Even with a tune and a MBC. Just let it warm up for a minute. It's not good to run a cold car hard anyways
Old Mar 9, 2011 | 12:37 PM
Creativeindy's Avatar
+1 Mine has done this stock and tuned. Doesn't much matter, if it isn't fully warmed up it's like riding a bucking horse.
Old Mar 11, 2011 | 07:57 PM
McDougal's Avatar
Good to know it's normal.
Old Mar 12, 2011 | 10:05 AM
blknblubkrdude's Avatar
Sorry to ruin the positive attitude in here, but this is not normal. Mitsubishi did not hire engineers to design a car that runs poorly when cold.
Yeah, it is a common problem, which might make it seem normal, but I assure you it is not.
Old Mar 12, 2011 | 10:20 AM
WolfsFang's Avatar
care to explain? My car does the same when its cold. I would hold the gas pedal even and the car would feel like its jerking back and forth a little. Shortly after it stops when the car is warmed up more.
Old Mar 12, 2011 | 02:18 PM
evo8john's Avatar
Could be a failing 02 sensor or fuel pump messing with the fuel trims at idle...
Old Mar 12, 2011 | 02:30 PM
4wdrifter's Avatar
I assure you that bot my o2 and fuel pump are fine. If your car runs perfectly the second you fire it up you must. Have the greatest Evo on the planet. I have several friends with evos and not a single one runs perfectly when it is fired up. Granted it only takes a minute or two to get the oil running through it...
Old Mar 12, 2011 | 03:04 PM
tscompusa2's Avatar
i would look into the low coolant temp timing trim causing the jerking when cold.
Old Mar 12, 2011 | 03:43 PM
styles's Avatar
Mine has done it since day one of owning it and with only 5miles on it. When the car is cold and I take off without letting it warm up it hesitates and jerks. As soon as the temp needle moves it stops doing that. I have a buddy that has the same exact problem. Thats why I just wait for the temp needle to move and then I go. So I wouldnt stress over it imo.
rm4g3d0n
Sep 20, 2017 08:48 AM
Willott03lancer
Lancer Tranny/Drivetrain Tech
Sep 17, 2015 02:04 PM
michaelanjolo
Sep 16, 2015 09:27 AM
blaze_125
Lancer Troubleshooting
Dec 2, 2011 09:52 AM
flo2877
Nov 9, 2005 08:26 AM
