How to put on exhaust valve stem
Noob question I know but I need to put one on and its a TIGHT fit, is there a tool to do this or does everybody use just a socket or something and push/tap it down? It's not going down as smooth as ones I've done before (only replacing one on this motor tho), which were for a stang and had different style seals but just wondering is theres a trick to put these on?
What tools are used?
Use a deep socket (12MM I think) that will just fit around, but not touch the spring. Tap on socket squarely with something heavy and metalic. Listen to the sound, it will change once seated, like - tap, tap, tap, tap, tink
I had only gotten one replacement, got a set today from extremepsi.com and will have a whole set tomorrow so I'll have extras if I mess one up.
As for the tool from Autozone I don't think they have a tool for the seal, and not sure if they got a spring compressor for OHC motors. I got one made from a modified C-clamp but only works on OHV motors like in my stang. I know a guy with a machine shop I might end up going there, he has a setup on his drill press that pushes the spring down to get the keepers in instead, save me some time goin to autozone and all that.
evoxsi
Jun 2, 2012 06:37 AM
katchup
14
Mar 13, 2012 02:26 PM
j_barcarse
Jul 7, 2011 09:50 AM
