slipping problem BUT!not from clutch...
Old Mar 15, 2011 | 03:51 AM
tsikisevo8's Avatar
i have a slipping problem like if the clutch is slipping but is is not the clutch.We have allready checked the transfercase and the rear diff and everything look fine!the driveshafts and the axles are ok also!what do you think that is the problem?the car is a evo 8 with stock transmission,shep tranfercase and rs rear diff. and aprox.580 awhp!
Old Mar 15, 2011 | 04:09 AM
evo8john's Avatar
Need more info... Is it doing it on a WOT pull or daily driving? What gears is it doing it in? What clutch do you have in it currently?
Old Mar 15, 2011 | 05:43 AM
Kracka's Avatar
How have you confirmed it's not the clutch?
Old Mar 15, 2011 | 06:07 AM
sharkm87's Avatar
this is like a math equation...the answer is E. not enough info
... define the variable slippage in the equation.... are the rpms jumping and dropping.... or you talking about driving on ice
Old Mar 15, 2011 | 06:27 AM
MR Turco's Avatar
There nothing to really slip other than the clutch and tires.
Old Mar 15, 2011 | 06:30 AM
sharkm87's Avatar
right... unless he is using the wrong terminology to define the issue... idk... not sure what checked the transfercase meant either?....visually?
Old Mar 15, 2011 | 11:21 AM
Highboost26's Avatar
Check your Axles .. I am a similar problem before , mine was a right rear
Old Mar 15, 2011 | 12:50 PM
barneyb's Avatar
^^^ Yeah, shaft with splines, now, no splines - that would do it.
Old Mar 15, 2011 | 12:59 PM
596736's Avatar
I'm curious how you ruled out the clutch though?
Robertv34
34
May 19, 2020 12:01 AM
dac001
Jan 3, 2016 05:05 PM
partyboy1122
Dec 15, 2011 09:48 AM
xsolowx
Aug 20, 2008 03:11 PM
Max Rebo
10
May 27, 2005 05:15 AM
