Code PO171 Problems
Old Mar 29, 2011 | 02:00 PM
wooby99's Avatar
Code PO171 Problems
My wife's 06 Evo just threw code Po171 on the way home from work. Did some research on it, but here is the baffling part. Normally the vacuum is 13-18 at idle, now it's 25 and when you give it a little gas it goes up to 30. She said it will still boost, but not sure if like before because with code she didn't want to hurt anything. This was noticed after ses light came on. This should eliminate some causes for this code. Need some input on this on were to look....wife doesn't want to drive her baby with this problem. Thanks
Old Mar 29, 2011 | 02:42 PM
barneyb's Avatar
The only way I know of to make the manifold vacuum increase is to plug the intake. Something is wrong there. It sould be easy to locate with a little inspecting.
Old Mar 29, 2011 | 05:34 PM
06RedRalli's Avatar
That code is due to a lean condition in bank 1.
Old Mar 29, 2011 | 09:15 PM
barneyb's Avatar
Yeah, I know, engine starved for air and reading lean. Unless her boost gauge has gone completely wacko, I gotta think something has happend to the Mass Air Sensor causing it to give a bad reading - maybe the honeycomb or air filter has collapsed.
Old Mar 29, 2011 | 10:03 PM
06RedRalli's Avatar
Possibly a bad o2 sensor.
Old Mar 29, 2011 | 10:56 PM
barneyb's Avatar
Remember, the OP said the vacuum is going to 30 with a little throttle (actually the vacuum can't go to 30, that's the vacuum of outer space - but gauges aren't all that accurate). So, anyway, whatever the actual reading is, it is abnormally high. I've read here of people with big turbos having sucked the honeycomb in.
Old Mar 30, 2011 | 05:01 AM
wooby99's Avatar
Thanks for the input. Had pulled the code with a scantool and got all the info printed out from alldata. Trying to narrow it down to make quickly fix the problem. My wife works days and me nights so I got about an hour each day to work on her Evo.
pitbulllove2003
Dec 28, 2014 04:40 PM
DreamerAndy
Oct 31, 2012 05:43 PM
boostslut
Jan 30, 2012 11:24 AM
Jo§h
Lancer Engine Tech
16
May 2, 2009 10:44 PM
awdwannabe
Midwest Region
10
Feb 13, 2009 01:30 PM
