JohnBradley's 2011 car update.
Old Apr 7, 2011 | 05:25 PM
  #121
boostedwrx's Avatar
Mikey has the I-beam, Aaron has the H-beam. I think I'm going H-beam.
Old Apr 7, 2011 | 05:27 PM
  #122
JohnBradley's Avatar
I beams are 680g, Manley I beams are 680g. The phase 2 GSC H beam is around 580g +/-, mine weighed in at 602 according to my notes.
Old Apr 7, 2011 | 05:29 PM
  #123
BLKCarbonEVO's Avatar
Originally Posted by 3gEclipseTurbo
I thought Aaron said you have GSC H-beams?
I hope not, I paid for an I beam...
Mikey
Old Apr 7, 2011 | 05:32 PM
  #124
3gEclipseTurbo's Avatar
Mikey
Im sure you got I beams then
Old Apr 7, 2011 | 06:13 PM
  #125
R/TErnie's Avatar
just so you know I'm doing a little dance over here... its the one where your arms are out to your sides and make a wave like motion... I like my R&R's its too bad they don't stock those rods.
(edit: because my rods are light )
Old Apr 7, 2011 | 07:20 PM
  #126
R&R=588g (as a 159mm mind you), and we dont stock any rods but I can get ANY rods
Old Apr 7, 2011 | 07:48 PM
  #127
EvoDan2004's Avatar
so the 94 spools up the same as a 86? how was this achieved if you do not mind saying. i am on a 2.0L and would like to try the 3794 but im afraid of 500rpm+ lose spoolup
Old Apr 7, 2011 | 07:56 PM
  #128
Boost actuated dump might be helping some, other than that its something in the combo I havent been able to determine...maybe the housing being the same size.
Old Apr 7, 2011 | 07:59 PM
  #129
EvoDan2004's Avatar
does the 3586 fit this 3794 housing? or you mean both being a .82 or whatever they are
Old Apr 7, 2011 | 08:11 PM
  #130
project_skyline's Avatar
GSC has LR I beams? And they weigh 680 as well?
Do you think your fuel limit is the pump, injectors, or something else?
Old Apr 7, 2011 | 08:36 PM
  #131
Correct, I am running the 156 GSC I Beam.
Mikey
Old Apr 8, 2011 | 08:35 PM
  #132
Stock base pressure on the fuel side, backpressure on the power side.
Old Apr 8, 2011 | 08:36 PM
  #133
Physical dimensions are different, but its still a 0.82 A/r T3 like I had.
aaron
Old Apr 8, 2011 | 09:44 PM
  #134
evolvd276's Avatar
What if you went with a t4 will that help the top end and loose the mid I did a standard 2.4 is there huge downside to not going with the lr just max revs ?
Old Apr 8, 2011 | 09:52 PM
  #135
tscompusa2's Avatar
Mikey
so the GSC h beam are stronger then the manley h beam, but are the GSC i beam equal to the manley i beam or is the GSC i beam stronger as well?
and a loaded question for anyone.. sorry I'm not to smart when it comes to engine internal parts.. (and lack of research), but
what is the strongest rod available for the 4g63?
i always thought it was either oliver or pauter?
