cant boost over 30??
Old Apr 14, 2011 | 10:59 AM
evopowned's Avatar
Originally Posted by Arkitek
you're trying to hit 34psi on an oldschool green? is the car fully built? if you're just doing this on stock block and some bolt-ons then you're not going to get to 34psi....
not fully built the bottom end is stock, have headstuds cosworth headgasket cant remember the specific size, cams springs retainers etc....
Old Apr 14, 2011 | 11:00 AM
evopowned's Avatar
Originally Posted by sparky
You can try a two step elimination process to see if and whether it is your BOV, or your EBC that is causing the problem.
1) Block off your BOV by inserting a thin piece of sheet metal in between the BOV flange and the IC pipe.
2) Disconnect the EBC and run a length of 4mm rubber hose from the WGA nipple to the nipple on the compressor housing discharge pipe. Now increase boost manually by turning in the turnbuckle clockwise on the end of the threaded WGA arm till you reach your desired boost level.
ive tried something similar to this.. tried to flip the bov around to make the pressurized side push the valve closed and still got same results
Old Apr 14, 2011 | 11:06 AM
evopowned's Avatar
The wastegate has that adjusment part on it which is threaded about half way.. in theory in my head i would imagine if i tighten the wg arm (threading all the way down so no threads can be seen) this should alow the wg to only open the flap a little bit correct? or not as much as it is now which in turn might mean i can create more boost?? im not a scientist when it comes to this subject so i appoligize for stupid question i may ask. thanks for any more suggestions or things i may check
Old Apr 14, 2011 | 05:16 PM
sparky's Avatar
Originally Posted by rstchris
I love ebc's but from what I have seen, they can only double the wg pressure at best......
So, if the above quote is correct then you could try increasing wastegate spring pressure up to about 20 PSI, then the EBC will regulate boost starting at 20 PSI up to 40ish. From experience I know that this is how it works with an MBC. But, I know next to squat about EBC's.
When I initially read your opening post I suspected that your spring pressure might be too low for running that high of a peak boost level(38PSI).
Don't be fooled by that advertised 18 PSI rating of the FP actuator. I have one and as delivered from FP it opened at 14 PSI on my old Green.
Old Apr 14, 2011 | 06:16 PM
evopowned's Avatar
I dono much about my evc either just know how to set it up and target boost and the offset. What spring are you talking about exactly when your talking about spring pressure? My wg spring?
Old Apr 14, 2011 | 07:54 PM
sparky's Avatar
Originally Posted by evopowned
...... What spring are you talking about exactly when your talking about spring pressure? My wg spring?
Yeah, exactly, I was referring to the WG spring. Actually, in my little mind I think of it as WG preload. I don't think that the terms wastegate spring pressure and wastegate preload are synonymous in a strict sense. But, I initially if mistakenly thought of it as wastegate preload.
You probably need to preload the wastegate spring more. Rotate the turnbuckle on the threaded end of the actuator rod INWARD, clockwise which effectively shortens the overall length of the rod which will keep the flapper valve on its seat longer and make it more difficult for the diaphragm to counteract the preloaded spring pressure.
Before you start dicking with the actuator rod adjustment though you can try to find out roughly what your wastegate spring pressure is at currently. If you've never done it before you can approach it in a couple of ways. What happens if you turn your EBC down to its lowest boost setting possible? I'll bet that your peak boost level will be somewhere between 12 and 14 PSI.
Old Apr 14, 2011 | 08:01 PM
evopowned's Avatar
Actually did this about a week ago and it hit 16 psi if I remember right. I'd go try it right now but had to send my fuel injectors in to get tested for leaks. But the actuator adjustment was only half way so I adjusted it all the way down to shorten it maybe this is my problem on why I can't reach boost levels I want. Maybe will help when shifting through gears was only hitting a peak of about 27 through 1-3 gear 4th would hit 30 because it was so long.
Old Apr 14, 2011 | 08:18 PM
sparky's Avatar
Yeah 14 to 16 PSI is too low for good transient response and quick spoolup. You need a minimum of about 18 PSI of preload on there for running 21 PSI of peak boost. As a rule of thumb, you'll want wastegate spring pressure to be set at a level just 2 to 3 PSI below peak boost.
I personally have no experience with boost levels above 27 PSI on my Old School Green. But, you are at a level where a 25 PSI WGA might not be a bad option. Before the 25 PSI actuator there were a couple of Meth injection guys running the 18 pound actuator at over 36 PSI. BlackCarbonEvo also runs relatively high boost levels on the 18 pounder.
Most of these guys ended up having to trim some threads off the end of the actuator rod though to optimize spoolup and boost holding. So, if you tightened THE TURNBUCLE END ALL THE WAY DOWN AS YOU DID HOW MANY THREADS ARE LEFT SHOWING?
Old Apr 14, 2011 | 09:18 PM
evopowned's Avatar
Maybe I need to get the stronger one then. None of the threads are left showing now
prEVOke
Oct 20, 2015 01:31 AM
Trale.Lewous
Northwest Region
Nov 2, 2011 09:35 PM
linjy2
24
Nov 2, 2009 06:19 AM
hawaiian_evo
May 8, 2007 04:57 PM
losdog47
27
Nov 14, 2006 05:39 AM
