3rd and 4th gear trouble
Old Apr 10, 2011 | 03:33 PM
From 3 to E's Avatar
I went to the track last night for the first time (for both me and my ). my launch went fine (although i need to lower the 2-step) and my first to second gear change went fine, but on both my runs i just cant get it in third! its like i just hit a gate/wall and i cant get it in unless i get off the gas (disengage the no-lift-to-shift) and let the rpm's fall a little bit. if i do that, itll go in, but ive lost my time and power.
I notice it a little on roll racing too. I have to shift a little slow and be precise when going into 3rd on the no-lift-to-shift. it works fine, but i cant power-shift it by any means like i was 1-2 gear.
question is this: am i just a bad driver? or are things in my motor bay moving too much on 100% throttle and no-lift-to-shift? if the latter is the case, would motor mounts help me with this?
setup: sc61 at 27lbs of boost, built motor, quartermaster twin disk, all stock mounts for motor/tranny/rear diff.
Old Apr 10, 2011 | 05:45 PM
inf0's Avatar
you might have to adjust the clutch, try changing youre shifter bushings also
Old Apr 10, 2011 | 07:09 PM
ive got the clutch adjusted where engagement is several inches off the floor. unless the clutch needs to be bled again, i dont think thats it..
there is an inch or two of pedal "slack" before feeling pressure though (on engagement).. maybe a re-bleed?
Old Apr 11, 2011 | 11:11 AM
bump? anyone notice a difference after getting mounts? or should i look elsewhere for the issue?
Old Apr 22, 2011 | 10:18 AM
speedingtwinky's Avatar
shifter bushings. Front motor mount. Re-bleed. Start there...
Old Jun 14, 2012 | 07:50 AM
gypsy's Avatar
Bump, I have a tough time going into fourth myself when using no-lift-to-shift. Did you ever get it resolved? It feels like the synchros are going out
David Buschur
477
May 28, 2020 07:16 PM
Seth_Horton92
Feb 9, 2017 07:13 AM
Dmx3alo
Jan 20, 2017 02:28 PM
scheides
Mar 1, 2014 09:45 AM
odin
Mitsubishi TC-SST Discussion
12
Oct 26, 2013 05:14 PM
