Cold start issues
Old Apr 13, 2011 | 09:14 AM
nytalonTSi's Avatar
Cold start issues
Having cold start issues, I notice if I don't allow my car to warm up for at least a few minutes and I try to drive off as soon as I put the car in gear and rev the car sputters, idle drops and unless I put it back into neutral or rev higher then usual. At the same time the idle surges and the afrs are all over or lean.
After a few minutes, it's fine. Only changes made were, I have deleted the egr and disabled it through ecu, added a silicone intake pipe and replaced shaft seals in throttle body.
Help is appreciated, thanks.
Old Apr 13, 2011 | 12:04 PM
nytalonTSi's Avatar
Adding to the issue, on a cold start the idle surges and if I push the clutch pedal in and rev the motor sputters and wants to stall. After the idle settles, the problem is gone. So I'm looking at a open loop.
I'm stumped, what should I look into? ISC, TPS?
Old Apr 13, 2011 | 01:37 PM
barneyb's Avatar
I'd suggest an air leak at the throttle body.
Old Apr 13, 2011 | 01:54 PM
nytalonTSi's Avatar
I did a blt after blocking off the egr. I used an oem gasket without rtv and blockoff plate I had from extremepsi, found a leak at the blockoff.
So I bought a fel pro gasket, it's kind of like carbon fiber looking and it sealed. Wasn't leaking anymore.
I'll do another blt. Anything else?
Old May 4, 2011 | 05:03 PM
Cory99GST's Avatar
Do you run e85? both my cars gst & evo like to warm up b4 u get in and go otherwise, just like yours, they spit and sputter until they warm up
Old May 7, 2011 | 08:49 AM
nytalonTSi's Avatar
Bump, it was kind of chilly this morning. Had crappy idle surge, almost stalled couple times and had to blip throttle for about a minute.
Nope 93 pump gas.
H8WRX
Jan 20, 2024 09:44 AM
Tw3NTy0n3
Feb 17, 2017 08:57 PM
mctonyb
Sep 11, 2016 09:41 PM
overdrive1
Dec 12, 2013 07:06 PM
Tim2s3
10
May 29, 2011 02:10 PM
