New setup won't start, help?
Old Jun 11, 2013 | 01:28 PM
  #31
TheBoz's Avatar
Can you take a datalog. Log the Stat Sync'd. While cranking that should go to 'Ok/True/On', I dont remember which one.
Did you set your base ignition timing? Where did you get your base cal?
You more than likely need to increase, your crank injector time table, start enrichment, and maybe a few other thing.
PM I can give you a hand.
Old Apr 21, 2014 | 10:16 PM
  #32
3K's Avatar
3K
Bump
I know this is a very old thread but I am in a very similar situation. Any updates? Or anyone dealing with this same scenario with a solution?
TIA
Old Apr 21, 2014 | 10:38 PM
  #33
batty200's Avatar
Check the coolant reading from the ECU. If the coolant temp sensor is unhooked or bad this is what will happen. It injects way to much fuel because it thinks it is -74* or something like that. Just a thought. Good luck!
Old Apr 22, 2014 | 03:34 AM
  #34
3K's Avatar
3K
Thank you, will do. Would that be the front sensor or the back sensor? I did notice coolant kinda leaking from the front sensor. The one by the t-housing.
Old Jul 17, 2016 | 12:57 PM
  #35
Evolution7GSR's Avatar
any updates on this?
fostytou
359
Oct 23, 2025 09:54 AM
RUNNING.AMOK
Aug 11, 2017 10:08 AM
Murf
May 29, 2017 01:11 PM
ezzey
Jul 19, 2016 04:48 PM
