2.4 started and ran, now wont start.
Old Apr 15, 2011 | 04:10 PM
Turbo01s2k's Avatar
Alright guys, have a confusing one. I recently finished my 2.4 build, got everything buttoned up, started the car. It fired right up, ran good, or as good as it was going to with my old map still on the car. I drove the car for 40 miles, everything was ok. Holes in the map, but to be expected. Loaded the car in a trailor, took it to be tuned. Started it, pulled it out of the trailor. Got the car on the dyno, strapped down. Did a calibration to 5k, let out of it, car fell threw idle. Since, it WILL NOT start. I checked the timing, it didnt jump a tooth. Here are my symptoms:
-Tries to start, but when i give it gas, it has no response.
-Got an engine code for "Cam position sensor malfunction", switched out both cam sensors with known working ones, off a buddys car and no start. His car is fine with my sensors.
-No spark. When i test for spark, i have nothing.
-Piston 1 and 2 are COVERED in fuel, 3 and 4 are ok.
Any guesses? Some are suggesting timing may be off. I will pull everything off and retime the motor tommorow if need be. Crank sensor? Something weird?
Any help or ideas would be appreciated!
Old Apr 15, 2011 | 04:59 PM
soulesswarrior's Avatar
Sounds like timing if u got fuel everywhere
Old Apr 15, 2011 | 05:04 PM
Turbo01s2k's Avatar
I agree. But timing is good still. TDC on the crank, cam marks are lined up. The same way the car ran before. I will retime it if i have to. Fuel pressure spikes to 45 on cranking, and drops to 30 after i stop cranking. SO i know pressure is there...
Old Apr 15, 2011 | 06:40 PM
I'm not too sure on this as I've never done a build like that but I assume u used a bottom end of a 4g69 or some other motor? Wonder if the timing may have to he modified
Old Apr 15, 2011 | 08:29 PM
Turbo01s2k's Avatar
Im thinking the ECU is fried. I had an issue with low voltage while trying to flash, and the code that it is throwing a symptom of that. I may just go stand alone and see where that puts me. The timing stuff would make sense if the car never started. But it started, ran, and drove.
Old Apr 15, 2011 | 08:33 PM
L@Ncer06's Avatar
What timming belt did you use? Also did you retard the timming ?
Old Apr 15, 2011 | 09:04 PM
Turbo01s2k's Avatar
Gates 4g63 belt. Yes, retarded the timing. The car ran...just doesnt now!!
Old Apr 16, 2011 | 05:40 AM
turbo speedy's Avatar
crank sensor? do you have any loose grounds?
Old Apr 16, 2011 | 06:19 AM
L@Ncer06's Avatar
you said you have no spark if you can switch the coil packs and see if you get spark?
Old Apr 16, 2011 | 07:28 AM
Turbo01s2k's Avatar
Coil packs, and cam sensors were both switched with know working ones, and had no avail. I also thought it may be grounds. I may go today and run some random grounds all over the place and see if it helps.
Old Apr 26, 2011 | 09:58 PM
Pitside's Avatar
Without a crank sensor there will be no spark. Check for loose connection.
Do you have a DVOM?
Old May 1, 2011 | 03:43 PM
xceler8rob's Avatar
same issues here... except mine never started.
https://www.evolutionm.net/forums/ev...tart-help.html
Old May 3, 2011 | 08:22 PM
TheBoz's Avatar
I just posted a reply to your post, I hope it helps.
Old Jun 1, 2011 | 11:04 PM
dotman05's Avatar
try another ecu, if there was spark and now there is none..sounds pretty weird
flashing ecu's on low voltage is not a good thing..
Old Jun 2, 2011 | 12:43 AM
3grst01's Avatar
Your buddy let you use his cam sensor why not try his ecu ... ?
memphis raynes
AEM EMS
10
Jan 19, 2014 09:34 AM
projektevo9
Jul 31, 2012 09:03 AM
Turbo01s2k
22
Apr 18, 2011 08:17 PM
dooby69
17
Mar 17, 2011 06:21 PM
TurbotrixRacing
Turbotrix Racing - Edison, NJ
Jul 25, 2010 04:35 PM
