Exedy Twin Failure? Need Diagnosis Assistance...
Am I at any risk for this right now? I plan to fix this asap but all the same, because I have never adjusted the fork, have I done any damage to my car?
mines adjusted very close, and i have zero issues.. adjust it to far out once and have fun dropping the trans and popping back on the wedge collar.
I refuse to run the clutch stopper for all of these reasons. If you consistently manage to pop the clutch off, switch to a push style. I've been running the Exedy twin for a long long time and have yet to have issues like this. Hundreds of drag launches too boot
but i still have the stopper just in case anyways. in 3000 miles mine hasnt changed its gap yet.
Hey all (again),
As a result of graduating from the college phase of my life I have still made no progress on this but have been easy on the car and it has been driving fine. I did snap a quick (craptastic iPhone) photo of the stop just to see if you guys thought anything else might be an issue. It is really hard to tell with the intake still in, but I am pretty sure the tip of the stop is holding the fork up. What concerns me is how the threaded shaft is riding on the fork boot. I occasionally have inconsistent starts in first gear and wonder if its possible the boot sometimes holds the fork up just a bit. All the same it seems like that boot will, or has, worn a hole. I will take the intake off hopefully soon and adjust to what seems to be a basic consensus of 1/4" gap. If you guys have any other recommendations of things to do to the stop while I have access to it, I am all ears. Here is a photo of the gap:
EDIT: Let me know if that is too big... I figure bigger is better in this situation!
Its hard to tell because you cant see the end of the adjustment rod. Maybe take a picture with a flashlight shining on the end of the rod. Also dont worry about the rubber getting rubbed on. It has no effect on clutch release or engagement of the clutch.
What exactly does the boot protect? I assume the boot keeps debris out of the inner workings of the clutch including the mating surface.
You are correct. It cant be that important though because that opening is a lot more if you convert to a push type clutch. The fork lever is taken out and 2 lines come out of that hole instead. Nothing to worry about.
Hi guys,
This is an update to my Exedy Twin HD clutch issues. I have adjusted my fork stop 2 times now, with the prior gap quickly being eaten up requiring readjustment. After both adjustments, the clutch action and feel dramatically improved. It was a night and day difference, no noise, quick and easy take up on the clutch. However, after every adjustment, groaning noise and inconsistent engagement slowly returned.
This is the case after the second adjustment, there is significant groaning during engagement and only about half of the time does the clutch engage smoothly. I thought that it simply need another adjustment and was being held up by the fork stop. Not the case this time... there still remains a ~1/8" gap. Though there may be some adjustment to be made in the pedal, in general, the shifts are smooth and the clutch appears to be fully disengaging. In addition, though I have not been beating on the car, there do not seem to be any slipping issues. So, any clue as to what the noise and engagement issues could be now that the fork stop gap has been fixed?
I am at about 1/8". My issue is that I am still having some groaning/ poor engagement issues with the fork stop adjusted properly.
The adjustment is through an aftermarket fork stop device installed on the clutch actuator. It simply has a threaded rod with lock nut to adjust.
bbong
Jun 11, 2017 05:25 AM
DOUGLAS
Sep 26, 2011 08:27 PM
