diy 50 trim setup
Old May 8, 2011 | 11:41 PM
rmrEVO's Avatar
diy 50 trim setup
Considering buying a t3/t4 50 trim turbo for my car and making my own turbo kit. Just curious what parts i would need other then these to make this happen.
t3/t4 exhaust mani
t3/t4 02 housing
38mm waistegate
oil lines
any input on what else I'd need would be appreciated thanks.
Old May 9, 2011 | 04:37 AM
Craig King's Avatar
Any particular reason you want to go with a t3/t4 setup???
Old May 9, 2011 | 04:47 AM
JakeTheVIII's Avatar
exhaust manifold gasket or make sure the old one is re-usable, water lines if the turbo is water cooled, T3 gasket between the turbo and manifold, 38mm wastegate gasket, seeing if your downpipe will work with the new o2 housing, hardware like nuts, bolts, washers, and any fittings (like AN) you need to make your oil return line
Raceghost
Dec 15, 2016 02:54 PM
igo4bmx
13
Nov 25, 2008 02:06 PM
evo_what
39
Jun 25, 2008 09:20 PM
dubbleugly01
Automotosports - Illinois
17
Oct 25, 2007 04:12 PM
OneFast4Door
Dec 9, 2006 12:07 AM
