Radiator doesn't suck in antifreeze..
Old Jun 15, 2011 | 04:55 PM
  #46
Colbyy's Avatar
So i got the new thermostat and the cap.. the cap seems like it goes on better then the other like it tightens twice. haard to explain. but im gonna put the thermostat in and want to know what i should use for antifreeze i mean it had green stuff but idk if i should switch well im at it. and should i do 50/50 or what?
Old Jun 15, 2011 | 05:20 PM
  #47
psphinx81's Avatar
yes green. 50/50 as well
Old Jun 15, 2011 | 07:04 PM
  #48
Colbyy's Avatar
alright thats how i had it but i was just wondering if i should do anything different well i was at it. hope to be driving her again soon. hope this fixes my problem
Old Jun 17, 2011 | 03:37 AM
  #49
Colbyy's Avatar
I think the cap may have been my issue even tho it was new i got another new one that actually has the 2 tightening spots. but what is the best way to put antifreeze in with out getting air bubble. to jack the front up so the radiator cap is the highest point, run the car to temp then fill slowly?
Old Jun 17, 2011 | 04:01 AM
  #50
psphinx81's Avatar
dont need to jack up the car really. leave it on the ground, start the car with the cap off from a bone cold start, let the car run till the fan kicks on and fill accordingly if needed
Old Jun 19, 2011 | 08:47 AM
  #51
Colbyy's Avatar
Well i drove it yesterday and it wasnt the new cap that didnt fix it. still pushed antifreeze into the overflow. Gonna do thermostat today just need a gasket for it. You dont need to drain the antifreeze to do it right?
Old Jun 19, 2011 | 06:37 PM
  #52
Colbyy's Avatar
what will i did for a gasket for the thermostat housing after i put the new one in? got a link to one or can i get it right at autozone
Old Jun 20, 2011 | 05:30 AM
  #53
barneyb's Avatar
The Evo thermostat comes with a gasket. BTW, you have to drain part of the antifreeze to install it. If you didn't get your new thermostat from Mitsu there is little chance it is the correct one. The parts houses sell only the Lancer thermostat which is smaller.
Old Jun 20, 2011 | 10:00 AM
  #54
afgtrackstar's Avatar
and when you bleed the coolant make sure to turn the heater on full blast!
Old Jun 20, 2011 | 04:46 PM
  #55
Colbyy's Avatar
i got it from here
http://www.trademotion.com/partlocat...layCatalogid=0
Old Jun 20, 2011 | 09:53 PM
  #56
barneyb's Avatar
Hopefully, the right one. You'll know when you get in there.
Old Jun 21, 2011 | 03:12 AM
  #57
Colbyy's Avatar
yeah guess will find out, hopefully doing it this weekend along with leak down test
Old Jun 25, 2011 | 12:38 PM
  #58
Colbyy's Avatar
Well it is the right thermostat and i see how you dont need a gasket but now i need the one to the motor. Broke a bolt off in the housing. so had to take the whole thing off. and in order to get to it had to take the intercooler pipes off, and pipe to turbo with airfilter. then all the turbo and coolant lines and sensors from the housing... Who ever said a thermostat was an easy project... haha just hope this fixes my problem after all this work and aggravation.
Old Jun 26, 2011 | 04:44 AM
  #59
MR. EVO MR's Avatar
hahaha, i broke mine too. I just dont remember removing all the stuff you removed Ha!
GL getting her back together and running soon, you can monitor the exact temps with evoscan.
Old Jun 26, 2011 | 08:33 AM
  #60
Colbyy's Avatar
Haha well I had to take the intake pipes and intercooler pipes off kuz there kinda too big PO put them in. Couldnt even get a wrench or socket in there. then it was just all the stuff attached to the thermostat housing. Whats 'Evoscan' ?
