EVO VIII Idle problem (with video)
Old May 30, 2011 | 05:29 AM
Jimbolution's Avatar
Hi,
here's a video from my EVO VIII idle problem.... with what we check, most of my contact talk about IAC or TPS that may be the problem.
with your expertise, i want to confirm that theory.
Just to introduce you, my problem start when the car has been running for like one minute after be warm a little on the idle.
here's the vid : http://www.youtube.com/watch?v=Sbf7zKuGonY
thanks
Old May 30, 2011 | 05:35 AM
ProKiD's Avatar
cams ??
Old May 30, 2011 | 05:39 AM
motocooney's Avatar
So..you say "idle problem"
What's the problem?
I don't see cams listed in your mods but it sounds to me your car is cammed.
It's idling at ~1000rpms, the AFRs are doing what they should be on a cammed car.
Your vacuum looks about right 12-14in/hg
Does it have cams?
EDIT: ^^^^^^this guy beat me to it. I'm sure you're car has cams and you just dont know it.
Old May 30, 2011 | 05:53 AM
loolll no cams in the car... i said the same thing to my friends.... sound's like cammed but for cheap price XD
i have the car since 2 years and i didn't put cam in it.
the car start this problem after a ride and it was a rainy day. I went home and a few hours later, the problem start... we check a lot of thing like injectors, vaccum, plugs, fuel pump, battery all the stuff but they found nothing....i've got a O2 sensor code and i change it but nothing... exept the code dissapear
so i call a guy that said : ohhh it should be the IAC, idle switch or TPS
so i want to be sure before buying pieces....
Old May 30, 2011 | 09:39 AM
dastallion951's Avatar
to be honest OP it wouldnt be your idle air control valve, because your idle will be surging and going up and down your stayed pretty consistent, now i have hks 272 cams, my car idles around the same as your as far as your afr 14.7-15.2 is what i have im running both the same gauges as yours. Now usually your tps will cause the afr to be erratic at idle....but will usually throw a cel code. Your best bet is to test the iac valve with a multimeter, test the resistance (ohms) on it turn it on with it out of the tb listen for it moving. As for lumpy idle without cams, maybe the starting of a bad lifter perhaps.
Old May 30, 2011 | 09:41 AM
i just noticed something in your video, your vacuum lines by the fuel pressure regulator, they look old cut and not ziptied down, thats a vacuum leak that could be causing some of the erratic idle, best bet get new vacuum lines, replace all of it under hood zip tie it all reset the battery n see if it gets better.
Old May 30, 2011 | 10:42 AM
dac001's Avatar
https://www.evolutionm.net/forums/ev...idle-hell.html
https://www.evolutionm.net/forums/ev...ease-help.html
Old May 30, 2011 | 11:40 AM
thanks buddy, i will follow his story too but it will help me to check a few things
Old May 30, 2011 | 12:06 PM
Evoryder's Avatar
I don't see what the problem is? The idle is solid, A/F is within range. It does have a slight lope to it.
I forgot what a stock engine looks like, been awhile
loms@
Apr 12, 2016 11:38 PM
benselements41
Oct 13, 2014 03:44 AM
pryde09
Jun 13, 2013 05:46 AM
Evo_AK
Sep 17, 2012 08:37 AM
congk
Feb 4, 2012 07:35 PM
