Blitz TT harness white wire?
I tried asking this before and got no answer so please help!!
I am trying to figure out where the seperate white wire with the round female plug goes. The harness has a three wire plug (red/blue/green) and then this seperate white plug. The package for the harness says Blitz "GTO" part no. is MI-02 and/or 51201 (the only English stuff on it). I got it from Adam at Z1 and he does not know. Did I get the right one? or does the white wire go somwhere I can't find? Thanks in advance for the help and Merry X-mas
Re: Blitz TT harness white wire?
I don't remember a separate white wire. You might have the wrong harness. I wish I had part #s for you, but he bought it. I do remember him saying it was the last generation turbo eclipse harness (sorry I don't know the gen #s)
Hope this helps
Re: Re: Blitz TT harness white wire?
Originally posted by S4IRISH
I did that same install two weeks ago on a friends EVO VIII.
Hope this helps
Hope this helps
Originally posted by mojo
Chronohunter,
did Zeus ever check to see if he had a white wire on his Blitz harness?
Chronohunter,
Originally posted by 1QWKEVO
i tinhk it's for skylines or sometihng.... jsut worry abotu the harness portion and the purple wire thats all that matters onalmost all cars...
Re: Re: Re: Blitz TT harness white wire?
Thanks, it does help. I'll contact Adam at z1 and have him double check.
I just noticed that you are in Boulder. If you need any help on the install, shoot me an e-mail.
to be honest i never fully understood what it was for, I jsut rmeember years ago someone mentioned sometihng about a skyline when making referance to that wire. For all I know I could be wrong....
Re: Re: Re: Re: Blitz TT harness white wire?
Not a problem. I'll try and find out what harness was used.
Re: Re: Re: Re: Re: Blitz TT harness white wire?
I may take you up on that if that harness turns out to be the "correct" one. BTW There is no mention of the seperate white wire in the in instructions it just shows the three wire plug the black grounds and purple wire
The harness is a 2nd Gen eclipse harness. See the link:
https://www.evolutionm.net/features/...e/rrmcorner/23
Although, there are no part #'s.
Re: Re: Re: Re: Re: Re: Blitz TT harness white wire?
Sure, let me know.
Sure, let me know.
Sorry I didn't get back to you... got caught up in the holiday scramble way down in South Texas... far far away from the land of DSL/cable modems/basic communications...
Looking at the English instructions I see:
Red wire - 12v constant
Green wire - 12v ignition
Blue wire - accessory
Black wire - ground
Purple wire - ground or hand break
It seems to me that you have either the wrong harness, or a different make. If you have access to an Evo wiring diagram, see if every thing "lines up" if Adam has no answers for you... bet he will though.
Black wire - ground
are u guys talking about the wires in the "harness" which is the adapter that goes into the key switch, or the extra wire that comes off the back of the TT...? I think that extra wire is white it's been a while since I paid attention to one
Pal215
18
Jun 11, 2017 09:47 PM
fireroasted
18
Nov 2, 2015 06:37 AM
