Something wrong with my evo
Old Jun 10, 2011 | 09:28 PM
btownsoccer22's Avatar
I made a thread a few days ago about my Evo making a thumping noise. Turned out to be a CV Axle and got that replaced. I know for a fact the car wasn't beaten on or test driven at the shop because I took a picture of the mileage and it was the exact same. Now on to the symptoms now:
I never noticed this before the thumping sound because if it was a CV Axle I didn't wanna boost at all but today when I went to do WOT in any gear something strange happens. The car builds boost, but it seems like it takes forever to build it. Then once it gets to about 5psi it seems like it starts to surge. THe boost keeps climbing but the car doesn't accelerate. And when I let off the throttle its as if the DV doesn't want to open.
I don't think changing a CV axle could cause anything like this? I checked my UICP and my LICP and they are both tight. Any ideas as what this could be? I can answer more questions if need be.
Thanks
Old Jun 10, 2011 | 09:32 PM
I don't know if surging is the right word. But once it reaches 5psi you can hear the turbo continue to make boost but the car doesn't go anywhere and it feels as if the turbo is sort of having a hard time making the boost...and it takes a long time to get to 26psi.
Old Jun 10, 2011 | 09:39 PM
GSX_TO_EVO's Avatar
have you checked for boost leaks?
Old Jun 10, 2011 | 09:41 PM
maevo8's Avatar
Take.off all ur pipes to make sure there not bent .. I have a thread on here same thing happen to me and I thought everything look good.unti I removed the pipes. Turns out my ic had a bent end tank .. hope u find out what it is ..
I checked my UICP and LICP. Already replaced my throttle body seals.
Old Jun 10, 2011 | 09:44 PM
GSX_TO_EVO's Avatar
Have you done an actual boost leak test or just checked to see if the clamps are tight?
Old Jun 10, 2011 | 09:51 PM
Just checked clamps...haven't done a boost leak test. BUt could a boost leak cause my symptoms? It seems more of a mechanical problem to me...should I take a video and post it tomorrow?
Old Jun 10, 2011 | 09:55 PM
GSX_TO_EVO's Avatar
seems to me like its a boost leak, sounds like an issue i had when my intercooler pipe was lose, the clamps seemed fine but it wasnt sealing right so it was leaking
Old Jun 10, 2011 | 09:59 PM
it must be a huge leak then. because my car doesn't go anywhere. ill post a video 2morro
Old Jun 10, 2011 | 10:27 PM
the turbo/engine makes a shudder sound once it gets past 5 psi
Old Jun 10, 2011 | 11:00 PM
Revo15's Avatar
see if the blade from the turbo is bent or broken...or maybe ur turbo is done!
Old Jun 11, 2011 | 06:02 AM
uhm...i think i may have figured it out...went to look at my hosing again this morning since I had more light and the t bolt clamp is physically off the lower intercooler pipe where it makes up to the intercooler...the t bolt clamp was just chillen there and u can spin it around
97laxlude
Feb 28, 2017 07:11 AM
Technical10
Jun 3, 2015 07:52 AM
nytalonTSi
Aug 3, 2010 11:36 AM
FL_SilverEvo8
26
Feb 9, 2009 11:15 AM
YEVOVIII
Mar 2, 2004 03:22 PM
