Which seal is leaking?
Old Jun 12, 2011 | 07:37 PM
Evilution23's Avatar
Hey guys. My transmission has a very small leak but its hard to pinpoint where it is coming from even after cleaning it and driving it for a couple of miles. The leak is not bad but it does leave maybe a quarter size spot on the driveway. It is around where the trans mates with the tcase and its definetely gear oil. I figure i post first then to start taking the drivetrain apart and then have the car sit. I included a pic its where those bottom two bolts are where it is leaking from. TIA
Old Jun 12, 2011 | 07:49 PM
BluEVOIX's Avatar
There is a little o-ring between the t-case and transmission. Most likely its that little o-ring gasket that is leaking.
Old Jun 12, 2011 | 09:13 PM
MasterNater's Avatar
+1
There are actually two o-rings, but with a leak that small, it is most likely the small o-ring.
Old Jun 12, 2011 | 10:52 PM
hyp36rmax's Avatar
i have this issue, i need to have my seals replaced very soon.
Old Jun 13, 2011 | 06:49 AM
Originally Posted by MasterNater
+1
at least from the looks of it i only have to remove the tcase and leave the trans in. i might as well just replace the two but do i really have to drain all the fluids out? is there anyway i can "reuse" the old fluid if i drain it into a clean container and put it back in. its only 1500mi old
Old Jun 13, 2011 | 07:32 AM
BluEVOIX's Avatar
Yes you have to drain both fluids.
You could reuse the oil if you drain in into a clean bucket. I know it isnt cheap but I would just go with new fluids for the piece of mind. I was in the same boat as you before.
Old Jun 13, 2011 | 11:11 AM
Yeah, no need to remove the transmission. Just unbolt the transfer case and move it towards the passenger side.
Old Jun 13, 2011 | 04:27 PM
grrr its so expensive!!! lol oh well if im change the fluids I might as well go amsoil.
grim~
Jul 5, 2018 02:32 PM
shuttersboy
May 6, 2016 10:27 AM
hiboost2.0
Oct 8, 2015 10:30 AM
Lambolution
Sep 4, 2010 03:25 PM
elhalisf
Sep 22, 2006 10:57 AM
