Eagle rods, fail!!!!!
Old Jul 15, 2011 | 12:12 PM
  #151
vikevo9's Avatar
Originally Posted by xRoguex
Is that a huge crack in your sidewall?
Yes, and water in the cylinder=kaboom!!!!
Old Jul 15, 2011 | 12:28 PM
  #152
supersal's Avatar
Ok so the crack let water into the cylinder and caused Hydrolock...
and basically this caused the rod to break.
So failure cant be blamed on a weak eagle rod - any rod would have failed in this situation...
Old Jul 15, 2011 | 12:32 PM
  #153
SmurfZilla's Avatar
I love this. So much detective work. Its like an automotive whodunit.
Old Jul 15, 2011 | 01:28 PM
  #154
1NastyMR's Avatar
I knew something else was the cause for your eagle rod to break...
Old Jul 15, 2011 | 02:19 PM
  #155
JohnBradley's Avatar
So what we learned today is dont blame anything to begin with. The title of this thread should have been-
"2.4L engine failure, what caused it?"
What happened instead was a bunch of bashing that didnt need to on both sides. Eagles werent the issue it and neither was the tuner or mechanic. It probably was fine, got a hot spot during tuning or a little too much cylinder pressure and a fabulous coreshifted block (sonic check the next one) and its all over.
aaron
Old Jul 15, 2011 | 02:51 PM
  #156
vikevo9's Avatar
"2.4L engine failure, what caused it?"LOL Thats true!!!
The block is bore to 87mm, I don't think that made the wall too thin. I bought the engine(without the head) fom a wreked car that probably overheted before. I'm just guessing. BTW I don't know of a shop here that do "sonic..." thing.
Old Jul 15, 2011 | 02:58 PM
  #157
Ricekiller81's Avatar
Diablo tremenda Raja pai! Part of the game man fix it and move on.
Old Jul 15, 2011 | 04:03 PM
  #158
evodude32's Avatar
I would definitely say the crack in the cylinder is what caused the rod to break, all that water coming into the cylinder hydrolocked the motor, all that pressure has to go somewhere, and it found the weakest link, the rod.. Although not saying eagle rods are weak cause I run them in a damn near 800whp car with plenty of tq and haven't had an issue. Not many rods will survive what yours went through though.
Sucks man, what are your plans now? sticking with the 2.4L? or back to 2.0L?
Old Jul 15, 2011 | 04:08 PM
  #159
n2oiroc's Avatar
now the question is, what caused the bore to split?
Old Jul 15, 2011 | 04:12 PM
  #160
vikevo9's Avatar
All ready bought a 4G64 engine!!!
Old Jul 15, 2011 | 04:15 PM
  #161
vikevo9's Avatar
I would like to know.
Old Jul 15, 2011 | 04:23 PM
  #162
Coreshift and high cylinder pressure I would assume based on how it looks compared to the ones we have had fail like that. Semi common in 2.4 blocks from Mitsu not so much from Hyundai. The other thing to keep in mind is a sonic check at the machine shop can tell you a lot. We have cracked 2.0L blocks with methanol issues, AEM malfunctions, and one 4G64 block that was shifted (I knew beforehand but didnt think it was that bad). Sometimes it seems it just happens.
Aaron
Old Jul 15, 2011 | 04:40 PM
  #163
n2oiroc's Avatar
Aaron
my block is half filled so hopefully im immune to it.
Old Jul 15, 2011 | 04:57 PM
  #164
It seems to happen the most on #1 at around 10:00 or so. Sean@FFTEC also has had this issue in the past and even sleeved blocks to get away from it. I have been thinking about 3/4 filling mine or selling it and building another one if I want to run over 800whp regularly. At 700whp +/- it seems to not be a problem. I know that Dave Buschur has also commented on this more than once as well.
Aaron
Old Jul 15, 2011 | 05:01 PM
  #165
vikevo9's Avatar
Guess I have to change my name to "CSIEVO9"
