how increase oil pressure???
How to increase oil pressure???
Hello guys, a friend of mine has an Evo 8. He blown his motor like three times!! He ask me, how can increase the oil pressure in his motor? and I donīt know how!!
Theres is a part to buy for do that??? Help me... maybe I can buy it too for my car!
Thanx, I will pareciate your help!!
Kiggleys HLA also increases oil pressure and helps keep more oil in the pan. I think people reported roughly 10 psi increase. Not sure if that's what RSmike was referring to when he mentioned "put restrictor in head" .
How about something a little more obvious...you haven't provided details on the blown motors of any kind--however, a thicker oil like say 20-50 would accomplish the same thing, bump the pressure a few lbs when hot and much more when cold or cooler then 100F like it is in tx.
Mikey
yup especially if has a built motor make sure you check the oil regularly the evos oil pan is very well designed for stock and gives plenty enough oil pressure. a balnace shaft delete will net you more oil pressure also.
Andrew@AMS
Automotosports - Illinois
26
Jul 7, 2019 06:20 AM
MRfabolous
48
Aug 17, 2017 07:15 PM
