AEM inline UEGO?
Old Jul 18, 2011 | 02:57 PM
killerpenguin21's Avatar
AEM inline UEGO?
Anyone run one?
I ran across this last night while searching. Long story short, I'm thouroughly fed up with trying to get my LC1 to function as well as with leaving 20+whp on the table by not being able to do any fuel tuning.
http://www.aemelectronics.com/inline...ontroller-1159
appears to be AEM's version of the LC1, and probably works a hell of a lot better in regards to keeping its memory, and sensitivity to wiring etc.
I'm assuming its the exact same as the UEGO gauge (controller wise)?
If thats the case, I would think it can use the same wire into the ecu as well as evoscan formula?
hopefully someone has some experience with one.
Old Jul 18, 2011 | 05:30 PM
n2oiroc's Avatar
i have it. besides aem having the wrong pinout info in the instructions its fine. 0-5v signal as most others do.
Old Jul 18, 2011 | 06:44 PM
wrong pinout?
i just want to wire it up like my lc1 running into the ecu, but unlike the lc1 id like it to actually work properly.
Old Jul 18, 2011 | 06:49 PM
n2oiroc's Avatar
Originally Posted by killerpenguin21
wrong pinout?
i ran the wires thru the stock rear o2 grommet and the plug was too big so i had to cut it off and pin a new one on. the instructions show 2 wires in the wrong spot. if you dont cut the wire and install it as is, its 100% fine.
Old Jul 18, 2011 | 06:53 PM
ah ok.
have you had solid performance from it/good sensor life?
i believe it uses the same bosch LSU 4.2 s the lc1 so im hoping to just have to swap out the in car stuff and not wait months till im on vacatin to get under the car.
Old Jul 18, 2011 | 06:55 PM
n2oiroc's Avatar
ah ok.
i just installed it so i cant comment on much. i think the ntk sensors are better, but they cost 2-3 times as much to replace.
Old Jul 22, 2011 | 05:51 PM
bump for anymore opinions, probably gonna order something tomorrow.
Old Jul 22, 2011 | 06:04 PM
lan_evo_mr9's Avatar
I run that sensor system without any issues at all. Starts off great, no erratic signals, easy to install however you want to, logging is easy, etc. It doesn't need calibration at all which is also a bonus and replacement sensors aren't bad on the wallet either. I highly recommend it to anybody.
Old Jul 22, 2011 | 06:56 PM
any chance you can confirm that it uses the same sensor as the lc1? im 99% sure but i doubt myelf lol.
Old Jul 23, 2011 | 05:22 AM
Drifting Away's Avatar
I have it it works great but I ended up finding a good deal on an entire zeitronix setup. Still the AEM did its job well jusgt they give you the wrong pinout information for building the cable.
Old Jul 23, 2011 | 07:37 AM
It'll be wired right into the ecu, so no cable to build.
Thanks guys
alfredoaal
Oct 20, 2015 12:35 PM
hashaam81
Jun 17, 2014 10:09 AM
iowa_guy
Cobb AccessPORT
Sep 28, 2012 08:11 PM
onyx1121
May 17, 2011 03:19 PM
PiNG
AEM EMS
Nov 14, 2006 07:33 AM
