Evo IX - "Service Engine Soon" light blinking under heavy boost
Old Aug 4, 2011 | 10:16 AM
llDemonll's Avatar
Originally Posted by ProPilot04
While this sounds legit, I'd probably go and have the tune tweaked to be a tad less aggressive just in case? You'd be sacrificing a tad of horsepower to prevent grenading your motor?
Just my opinion...
Originally Posted by AlisterMcRae
He said that if I am doing the same pull and the knock is consistant, then just swing by and he would fix it until winter rolled around.
That's what this is...fixing it.
Old Aug 4, 2011 | 10:57 AM
sktng22's Avatar
lol do the same pull and if it blows up ill fix it is what hes saying! i wouldnt do that pull again. id goto him right now and make him fix it on the dyno so if it blows they pay
Old Aug 4, 2011 | 11:51 PM
AlisterMcRae's Avatar
I am going to get it fixed this weekend, until then, I have been driving around like a school bus trying not to boost...haha
Old Aug 5, 2011 | 12:13 AM
AndyCT9W's Avatar
Low counts of knock isn't a major issue (debatable depending who you ask), a lot of people are content with 1 to 2 counts of knock and others won't tolerate a single count. Obviously 0 counts is ideal. I'm content with 1 count and a rare count of 2.
Have you logged a pull to see precisely how much knock you have?
Old Aug 5, 2011 | 07:55 AM
tiggeryellow1's Avatar
Veteran: Army
+1... Knock sum is kind of an anomaly. I mean it’s basically a harmonic irregularity given off by the motor that is picked up by a sensor (microphone of sorts) if I am not mistaking. So when using Evoscan during logging you may see your knock sum at 1…1…1 then jump to 7 then back to 0 just between 4000-4250 rpm range. Hell I have seen them climb as high as 35 on some Evoscan spreadsheets. Now don’t misunderstand me, I’m not advocating that this is Ok or that you should ignore it by any means! And if your CEL light is flashing the way that you claim then you have much higher and consistent counts than 1-3. I don’t recall exactly what the baseline parameters are in Tephra Mod 7 for slow flash CEL vs quick flash CEL but because yours is flashing at all definitely keep your foot out of it.
Old Feb 24, 2012 | 05:57 AM
pghdude54321's Avatar
Can anyOne direct me to a source that can fix this... I'm having the same issue bought the car modded I have the cable where can I find or who can I talk to to fix it?
Old Feb 24, 2012 | 06:27 AM
evo8426's Avatar
You need to use a Tactrix 1.3 or 2.0 cable, or find an Evo specific tuning shop to retune the car or contact an tuner on this site that does tunes via e-mail. On top of this you will need Ecuflash and Evoscan
BTW, you don't have a 2006 Evo 8. If it is a 2006 then it is an Evo 9.
Old Jun 26, 2012 | 05:57 AM
mrbooster's Avatar
I also got these falshing problems, but in low boost, it appears from .1 to .6. Was it a false knock? Once it reaches .7 bar it disappears and the car runs hard at high boost..
This had Happened only after i changed from ebc to mbc.
Old Jun 26, 2012 | 06:23 AM
CtSilver03Evo's Avatar
It may or may not be false knock. I would log your car (if you have a means of doing so) and post in the tuning section of the forum for people to look at your logs. If this is not an option, bring your car to a tuner and make sure you get it logged/re-tuned. New boost controller may have changed when your car comes into boost and you may be hitting different load cells with leaner AFRs or more timing, etc... You may just be in line for another tune.
jrmck
Aug 5, 2016 09:47 AM
Watcanbrowndo
Sep 27, 2013 06:52 AM
zhang695
Dec 18, 2011 07:41 PM
Seijuro
Mar 18, 2010 03:09 PM
rgar
Apr 29, 2009 04:53 PM
