Full blown twin pump install help
Old Aug 6, 2011 | 02:04 PM
NOMIEZVR4's Avatar
Hey guys,I've been following the instructions from
http://www.socalevo.net/forum/index....&topic=36405.0
Everything seems to be going ok except the wiring part. How do I wire in the first pump to the wiring harness?
The instructions on the site are for the wiring are for the valve float which I'm sure is for the stock gauge.
How can I wire in the first pump? I can see a red(positive)wire and a black(negative) wire coming out of the fuel pump. How do I wire that into the stock harness?
FYI...
For the second pump I will be using a hobb switch.
Old Aug 6, 2011 | 05:17 PM
MRfabolous's Avatar
i used the stock wiring harness to wire in the first pump just used the stock wires and ran the other off of a relay and my aem.
Old Aug 7, 2011 | 12:26 PM
NOMIEZVR4's Avatar
Thanks for the reply.
Thats what I plan to do, just a little help. I want to run the first pump off the stock wire and the second pump off a relay and hobb switch.
Can you let me know which wires off the pump hook up to which wires on the harness?
On the harness I don't know which hires are power/ground, after that I believe its a simple splice and join.
wizzo 8
Dec 27, 2023 12:15 AM
EvO_essence
Aug 11, 2016 07:57 AM
anthonyrb98
Apr 17, 2012 05:32 PM
cky3396
Apr 12, 2004 11:57 PM
Trustz
Apr 5, 2004 11:05 PM
