different 4g63???
Old Aug 15, 2011 | 04:30 PM
evoiao's Avatar
different 4g63???
Are there two different evo9 engines?
A generation1 casting and a generation2 casting?
if there is how can I determin which one I have.....
the reason Im asking is Im having valve seat fittament issues with a supertech dual spring kit.
Old Aug 15, 2011 | 04:31 PM
AWD Motorsports's Avatar
all the same.. if your having a seat issue you have the wrong seats most likely..
Old Aug 15, 2011 | 04:35 PM
evoiao's Avatar
ok well I bought spr-m1007d
seat-M1007d/fp
ret-M65/TSTD
VS-H6.6E
VW-H6.6I
the guy whos working on my car (evo9) 2006, was told by supertech that gen1 casting might require
seat-m1006d
what are your thought on this?
Old Aug 15, 2011 | 04:39 PM
evoiao's Avatar
more help!
Old Aug 15, 2011 | 05:05 PM
evoiao's Avatar
ttt
Old Aug 15, 2011 | 05:08 PM
Lowso's Avatar
this is all the help you need. All the motors are the same. unless you dont have a 4g63. all IX are the same man maybe get a new guy to work on your car.
Old Aug 15, 2011 | 05:09 PM
Lowso's Avatar
i see your in cali what part? if your in socal i can direct you to some good shops.
Old Aug 15, 2011 | 05:18 PM
evoiao's Avatar
for some reason im being told the the part i have seat-1007d
is not correct
but part number
seat-1006d is......
this is from supertech......I dont think the guy working on the car is the problem.....he has his own evo8 with over 1000 awhp
plus he working a civic race car, and has two lambo's there one yellow murcielago (v12) and one orange Gallarado (v10)
so i think its a wrong part.......
Supertech High Performance Valves: Mitsubishi
MITSUBISHI 4G63 2.0L DOHC TURBOINTAKE VALVEPart NumberEXHAUST VALVEPart NumberHead DiamStem. DiamLengthBlack NitridedHead DiamStem. DiamLengthBlack Nitrided / InconelEclipse / Talon / Lancer EVO34.00mm (std)6.57mm109.6mmMIVN-100730.5mm (std)6.54mm109.6mmMEVN-100734.5mm (+0.5)MIVN-100831.00mm (+0.5)MEVN-100835.00mm (+1.0)MIVN-100931.5mm (+1.0)MEVN-100936.00mm (+2.0)MIVN-101030.5mm (std)MEVI-1007*31.00mm (+0.5)MEVI-1008*31.5mm (+1.0)MEVI-1009*32.5mm (+2.0)MEVI-1010*ENGINE COMPONENTSVALVE SPRINGSOuter SpringInner SpringPressure (lbs@mm)Max Net liftCoil BindRateTitanium RetainerPart NumberO.D. (mm)I.D. (mm)O.D. (mm)I.D. (mm)SeatOpen (lift)mmmmlbs./mmPart NumberSPR-M1007S28.1020.00SINGLE76 @ 39.6200 @ 11.514.9024.7010.50RET-M65/T1 + Factory seatSPR-M1005D28.1020.0020.0015.2080 @39.6200 @ 11.516.0023.5010.50RET-M65/T1 + SEAT-M1007D + valve seal VS-H6.6-I*/VS-H6.6-E*SPR-M1007D28.1020.0020.0015.2092 @39.6235 @ 11.514.9024.7012.50RET-M65/T1 + SEAT-M1007D + valve seal VS-H6.6-I*/VS-H6.6-E*SPR-M1007D-228.1020.0020.0014.20100 @ 39243 @ 11.514.3024.7012.50RET-M65/TSTD + SEAT-M1007D + valve seal VS-H6.6-I*/VS-H6.6-E*SPR-M1007D-328.1020.0020.0014.20110 @ 38.1253 @ 11.513.4024.7012.50RET-M65/TSTD + SEAT-M1007D/FP + valve seal VS-H6.6-I*/VS-H6.6-E*BEEHIVE SPR-M1007BE-128.0018.8024.2014.5080 @ 38.6230 @ 11.515.3022.8012.80RET-M65/TBE + SEAT-M65BE-1BEEHIVE SPR-M1007BE-228.0018.8024.2014.5098 @ 37.2248 @ 11.514.0022.8012.80RET-M65/TBE + SEAT-M65BE-2VALVE GUIDESINTAKE: GDE-MI66-I (+0.03mm/ .001")EXHAUST: GDE-MI66-E ( +0.03mm/ .001")VALVE GUIDESINTAKE: GDE-MI66-STI (standard size)EXHAUST: GDE-MI66-STE ( Standard size)VALVE SEALSINTAKE: VS-H6.6-I (reduced OD diameter)EXHAUST: VS-H6.6-E (reduced OD diameter)VALVE SEALSINTAKE: VS-M6.6-IEXHAUST: VS-M6.6-E* Same 1st Gen castings may need to use a different seat locator SEAT-M1006D due to a taller valve guide boss.
Old Aug 15, 2011 | 05:20 PM
evoiao's Avatar
this is what is being recommended?
SEAT-M1006D Supertech Valve Spring Seat
Quantity in Basket:none
Mfg Part Number:
Code: SUP-SEAT-M1006D
Old Aug 15, 2011 | 08:18 PM
evoiao's Avatar
any ideas
yellowevo82
Aug 8, 2016 10:51 AM
Migsubishi
Aug 8, 2015 07:34 AM
thedru13
Jun 2, 2015 01:10 PM
3gEclipseTurbo
Nov 3, 2010 02:50 PM
evoWALO
Apr 6, 2007 07:54 PM
