Ryu's built motor thread (Sponsored by MAPerformance)
Old Nov 1, 2011 | 05:09 PM
  #76
RyuEvoIX's Avatar
Thanks Freddie.
Originally Posted by apagan01
Ryu i take it you are not in orlando anymore because there is a E85 pump on turnpike close to winter garden
congrats on the kid and gl ith the car sounds like you are having fun over there
I live 2 hours away, nearly 100 miles from Orlando. I've lived here for over 25 years now. Thanks. We are definitely having fun over here in many different ways.
Old Nov 1, 2011 | 05:54 PM
  #77
Mikey@Spec-Ops's Avatar
Originally Posted by Freddie@Spec-Ops
Congrats on the demon spawn Ryu!
Spec-Ops loves you Ryu
When is the baby shower, I'll send car parts!
Mikey
Old Nov 2, 2011 | 06:29 AM
  #78
wizzo 8's Avatar
Originally Posted by RyuEvoIX
Wizzo, I've yet to have any negative experiences with methanol injection with years of constant use. As tempting as it is to hop on the E85 wagon, unfortunately for me the closest pump is nearly 100 miles away. With this methanol setup I should still be able to pull out peak potential of my setup while having full power 24/7 without worries of needing a specific gas station.
I also ran meth for almost 3 years without any problems myself. Worked great. I would have stuck with it but I have an E85 station about 5min away from my house. I also have another one about 15 min from my house. This is what made me switch.
Old Nov 2, 2011 | 07:46 AM
  #79
RyuEvoIX's Avatar
Mikey
I appreciate the love. The shower should be in May.
I don't blame you for the switch. 5min away is far more manageable then 2 hours.
Old Nov 3, 2011 | 06:07 PM
  #80
danameisoj's Avatar
judgeracing ftw!!!
Old Nov 7, 2011 | 11:14 AM
  #81
RyuEvoIX's Avatar
Indeed!
Just a quick update. The new motor has nearly 100 miles on it. As per MAP's break in procedure instructions, the 100 mile oil change has been done. The car feels much more responsive with the higher compression then when I last drove it with factory motor. I'm pleased to say the least.
Old Nov 7, 2011 | 11:36 AM
  #82
Broham's Avatar
I didn't see but what motor is this exactly? Map 2.0? 2.3? What rods?
Congrats man
Old Nov 7, 2011 | 11:57 AM
  #83
danameisoj's Avatar
map 2.0 stage 2 .
manley tt rods
Old Nov 7, 2011 | 11:58 AM
  #84
forc3 f3d's Avatar
Congrats man
Stage 2 2.0 with Manley rods and high comp wisecos i believe.
Old Nov 7, 2011 | 12:03 PM
  #85
RyuEvoIX's Avatar
Correct. 10:0:1 compression.
Old Nov 7, 2011 | 12:41 PM
  #86
Broham's Avatar
Nice, good ol 2.0. I have been eyeing that map 2.0 stage 2 for some time. What did the higher compression help you with as opposed to the factory compression? Turbo tuff? How often do you think you'll need to replace the bearings due the I beam weight beatin it down? Just trying to get some info
Old Nov 7, 2011 | 02:04 PM
  #87
RyuEvoIX's Avatar
Higher compression= greater power potential. I chose 10:0:1 because i feel it will be a good match for the fuel I am using.
I'm not really concerned with the weight of the manley rods damaging the rod bearings prematurely. Imo, prolonged consistent detonation will wear them out much faster then even the heaviest rods on the market. In short, I expect the bearings to last a long time.
Old Nov 7, 2011 | 02:18 PM
  #88
Broham's Avatar
Thanks for the response. You going e85 100 %?
Old Nov 7, 2011 | 02:27 PM
  #89
RyuEvoIX's Avatar
93oct+ 100% methanol injection as always. I posted a picture of my direct port setup in this thread.
Old Nov 7, 2011 | 04:44 PM
  #90
forc3 f3d's Avatar
What meth kit are you using? I've been contemplating it lately... 92oct sucks!
