FIC 2150cc VS ID2000cc
Old Aug 27, 2011 | 10:12 AM
Dragking2189's Avatar
Hello Evom, I'm on the market for a set of injectors. I've been doing Some research and did come up with some good feedback on both of these. If there is anyone using any of these two injectors please chime in and let us know how you like these and how well they iddle? I will be runing these on stock ecu with speed density.
Old Aug 27, 2011 | 12:47 PM
n2oiroc's Avatar
I thought they were the same thing with the i.d.'s being more expensive.
Old Aug 27, 2011 | 12:50 PM
adam_79_2005's Avatar
with te ID2000cc injectors from what my mechanic said they are high impednce injectors which means running highly oxygenated race fuel is a no go such as Q16, however C16 race gas can still be used, with the fic 2150cc injectors, they are low impedence so Q16 can be ran aswell, as for E85 since we don't have any of that here i can't really chime in on that one, hope this helps.
Old Aug 27, 2011 | 01:06 PM
binky's Avatar
The FIC 2150's are high impedance injectors http://www.fuelinjectorclinic.com/cg...ey=IS226-2150H
They require a resistor pack bypass, something like:
Also, I have FIC 2150's and love them
-Bink
Old Aug 27, 2011 | 01:09 PM
-Bink
I stand corrected, I thought the fic 2150cc's were low impedency, thanks for the clear up brother
Old Aug 27, 2011 | 01:10 PM
binky's Avatar
Not a problem man!
-Bink
Old Aug 27, 2011 | 01:13 PM
javicracer's Avatar
both injectors are high impedence, you get what you paid for, pretty much the id are superior. Better flow, better idle, etc.
Old Aug 27, 2011 | 01:18 PM
CBRE's Avatar
I've had both, FICs hat fits much snugger to be leak and problem free, now have installed at least ten sets in cars no issues.
Old Aug 27, 2011 | 01:20 PM
Spec-Ops1's Avatar
Incorrect... the injector body is OEM, and to my knowledge not modified by either camp, ID just matches the injectors differently than FIC...
Old Aug 27, 2011 | 01:24 PM
CBRE's Avatar
FIC price and better upper injector hat should be a no brainer, Jens service is great also.
Old Aug 27, 2011 | 01:28 PM
Thanks guys, pretty much you cant go wrong with any of these 2. I will be using e85 I just want the best drivability from them as possible.
Old Aug 27, 2011 | 04:40 PM
mrboost05's Avatar
save your money and get the Fic injectors i run them on my evo but have the ID in my honda they both do there job but one at a higher price your car will run and drive better on thease then any other injector on the market do you like red or blue should be your only choice and you dont have to buy a resister pack bypass you can do this.
https://www.evolutionm.net/forums/ev...istor-box.html
Old Aug 27, 2011 | 05:27 PM
Thanks for your help, If I get with the FIC's can I use this instead of cutting?
http://www.streettunedmotorsports.co...elete_plug.htm
Old Aug 28, 2011 | 01:15 AM
evilempire76's Avatar
Yes. Pretty much the same thing as the Spoolin Up resistor pack.
Old Aug 28, 2011 | 05:39 AM
SmurfZilla's Avatar
-Bink
No need to cut if you use this.
ShiftyPenguin
15
Apr 10, 2017 10:13 AM
EmirEvoEight
14
Nov 2, 2016 06:20 PM
EvoIV_97
Oct 26, 2016 12:55 AM
Andres Mesta
Sep 26, 2013 10:29 AM
jameswwt
Dec 16, 2010 12:27 AM
