Turned up the boost but now making less boost
Old Aug 29, 2011, 06:09 PM
My03evo's Avatar
Question Turned up the boost but now making less boost
So recently had issues but they were fixed with closing the gap on the plugs and the lines on my boost controller were on backwards which made it run on wg pressure. Was running about 28 psi and my aquamist was NOT activating yet (set off the IDC). I cranked down my forge mbc about 4 full turns and now I'm running at around 26 psi...wtf?
Yes I did turn the knob the proper way and now the meth is kicking on so thats proof its making more boost (thus hugher duty cycle and activating the meth) but the boost gauge is showing Less...Any ideas?
Old Aug 29, 2011, 06:11 PM
FTY Motorsports's Avatar
u got a messed up boost gauge lol
Old Aug 29, 2011, 10:30 PM
sparky's Avatar
Originally Posted by My03evo
.... Was running about 28 psi.... I cranked down my forge mbc about 4 full turns and now I'm running at around 26 psi...I did turn the knob the proper way.....
So what boost level does the boost gauge indicate when you back the MBC knob all the way out counterclockwise to full soft? This will give us a pretty good idea how much preload, if any, your WG is running. Make note of how many full turns you backed the knob out from where you currently have it set until you reach full soft.
Old Aug 29, 2011, 11:01 PM
sparky's Avatar
Why dončt you swap on another boost gauge so that we can rule out a faulty gauge as the cause of your problem?
Old Aug 29, 2011, 11:04 PM
sparky's Avatar
Will you please post up your full modlist, i.e. what BOV or DV, full TB exhaust, larger injectors, ported manifold(s), and etc. Who tuned your car? What make of 272 camshafts?
rado
AEM EMS
Oct 17, 2016 08:29 PM
My03evo
12
Sep 26, 2011 12:26 PM
XSivPSI
Nov 25, 2009 09:37 AM
Lucas English
41
Jun 11, 2007 01:24 PM
TrinaBabe
35
Dec 11, 2005 09:25 PM
Quick Reply: Turned up the boost but now making less boost
