Ac delete and idler pulley
Old Sep 3, 2011 | 04:46 PM
211Ratsbud's Avatar
Do you remove the ac idler pulley too? I did and the belt suggested didn't work it is too long . Now I can't get the bolt back in that pulley hole because the hole is messed up from it being too long when I backed it out. Help!
Old Sep 3, 2011 | 07:06 PM
barneyb's Avatar
Having never done this conversion (I like AC) I don't know the answer to whether you remove the idler pulley or not.
As I recall, in order to remove the bolt you needed to first remove the engine mount and lower the engine until the bolt clears the frame. Now, you'd have to do the same thing and chase the threads.
Old Sep 3, 2011 | 08:12 PM
RJones's Avatar
I only removed the AC compressor and left the idler pully. Worked fine for me.
Old Sep 3, 2011 | 08:34 PM
211Ratsbud's Avatar
Crap when I put the belt in there it looked like it was touching itself when I left that one in there
Old Sep 3, 2011 | 08:38 PM
sho669's Avatar
Same here, OP maybe the belt you had was too long?
Old Sep 3, 2011 | 09:46 PM
211Ratsbud's Avatar
Got it, the belt is barely.long enough with the pulley in, used a short chassis bolt to chase the hole
Lancerfry30
Feb 25, 2017 10:40 PM
tucknroll
Lancer Engine Tech
Apr 6, 2016 10:31 AM
NadzOnFire
Lancer Troubleshooting
Jun 17, 2014 08:46 AM
mdsevo06
Dec 17, 2013 03:31 PM
