crankcase ventilation idea.....
Old Sep 3, 2011 | 05:11 PM
n2oiroc's Avatar
oil pan has a -10 fitting like this.
http://www.streettunedmotorsports.co...bo_fitting.htm
how about using a fitting like this and running a line to a catch can?
http://www.summitracing.com/parts/EA...0ERL/?rtype=10
Old Sep 3, 2011 | 05:17 PM
RSMike's Avatar
Will the "pressure" coming out of the engine push the oil from the turbo into the catch can as it might not have a chance to make it to the sump?
Or did you want to use that "T" fitting as a drain from the bottom of the catch can?
I'm going to be building a catch can, and run 2x lines directly off the back of the block (where the stock balance shaft sits), as well as the 2x lines off the head.
Old Sep 3, 2011 | 05:21 PM
n2oiroc's Avatar
i really doubt there would be that much pressure, if there was this would help and let the oil drain back easier. i dont intend to use it as a drain, i dont want and of that crap going back inthe oil. i guess i could carefully tape my block off and drill the block, but its already an assembled short block and i would rather not take the chance of any chips getting somewhere.
Old Sep 3, 2011 | 05:27 PM
240Z TwinTurbo's Avatar
You can do this, but you need a one way valve on the bottom of the catch can. You want to avoid drawing up oil from the pan. I have run a similar setup several times in the past with no issue. BTW, this is for a sealed catch can.
Old Sep 3, 2011 | 05:38 PM
n2oiroc's Avatar
ill be running a vta can so i shouldnt need a check valve. the only issue i was worried about was the drain from the turbo being affected.
Old Sep 3, 2011 | 05:39 PM
What is a vta can?
BTW, if the can is not sealed you lose the ability to draw vacuum on the block via turbo inlet. This is also a reason for the one way valve.
Old Sep 3, 2011 | 05:42 PM
n2oiroc's Avatar
What is a vta can?
vent to atmosphere, not sealed it will have a filter on top. like this.
http://www.summitracing.com/parts/MOR-85473/
i dont want any chance of the turbo sucking oil so i dont hook anything up to the intake.
Old Sep 3, 2011 | 05:43 PM
BTW, on the setup shown below for the twinturbo ZR1, I measured 3in of vacuum at the can with 7psi of boost.
Old Sep 3, 2011 | 05:54 PM
With the proper can sucking into the turbo should not be an issue. I fabricated my own, but you can buy proper sealed catch cans. Otherwise, you will build block pressure.
http://www.saikoumichi.com/
Old Sep 3, 2011 | 05:59 PM
n2oiroc's Avatar
i have never seen a catch can that actually caught all the oil, i even had an expensive mann hummel unit that everyone raves about that puked oil everywhere. i'd really rather just vent to atmosphere and not worry about it. thats what i did on my sti and it worked great.
Old Sep 4, 2011 | 01:57 AM
RSMike's Avatar
Is that top line going to a venturi pipe in the exhaust to create vacuum in the catch can and the sump?
Cheers, Mike
Old Sep 4, 2011 | 05:58 AM
Top line went to PCV and bottom was split to the two inlets of the GT3076r turbo's. However, I have seen the venturi ports on the exhaust and understand they are very effective at creating suction. There are a few internet articles on the topic and you can buy the weld on bungs from Summit Racing for cheap.
STM Tuned
Jun 13, 2018 12:31 PM
Nabster86
Mar 6, 2017 04:46 PM
STM Tuned
Feb 9, 2016 06:13 AM
4g63girl
Jan 13, 2015 10:04 AM
STM Tuned
Feb 6, 2014 08:35 AM
