4 inch intake..!
Old Sep 7, 2011 | 08:00 AM
babaz7's Avatar
4 inch intake..!
im installing a custom 4 inch intake pipe to my gt35r,will the larger intake cause any problem?
Old Sep 7, 2011 | 08:05 AM
wizzo 8's Avatar
Still using the stock maf?
Old Sep 7, 2011 | 10:22 PM
babaz7's Avatar
yes...will it work?
Old Sep 7, 2011 | 10:26 PM
novem's Avatar
Yes, and you might pick up a few HPs.
N
Old Sep 8, 2011 | 01:21 AM
babaz7's Avatar
N
thanks alot!
Old Sep 8, 2011 | 02:43 AM
babaz7's Avatar
and will i see changes in the AFR's? will it lean or rich?..and do i have to make any adjustments to my flash?
Old Sep 8, 2011 | 08:12 AM
BenJ's Avatar
You will go leaner, but depending on your tune, may not be an issue, just monitor your afr's.
BenJ's Avatar
Also, how big is the inlet to your gt35?
Old Sep 8, 2011 | 08:24 AM
babaz7's Avatar
4 inches...from the air filter to the turbo inlet.
and the turbo inlet is also 4 inches! its a gt3586r
Old Sep 8, 2011 | 08:30 AM
Kracka's Avatar
The MAF will be the restriction in your intake now since the outlet is just over 3".
Old Sep 8, 2011 | 12:10 PM
wizzo 8's Avatar
Just a heads up you may get some stalling at idle at times. Doesn't happen to everyone though
Old Sep 8, 2011 | 09:12 PM
babaz7's Avatar
i'll find that in about 2 days from now, i'll post the results if it stalls or not.
Old Sep 9, 2011 | 07:31 AM
Mikey@Spec-Ops's Avatar
Waste of time. The MAF is a 3" so no need for a 4" intake. Rip the MAF off and go SD and a 4" intake. You will prob gain close to 20whp just from doing that. Maybe more depending on boost levels.
If you need help setting everything up give me a holla
Mikey
Old Sep 9, 2011 | 06:26 PM
gone2pimp's Avatar
Originally Posted by mikey@spec-ops
waste of time. The maf is a 3" so no need for a 4" intake. Rip the maf off and go sd and a 4" intake. You will prob gain close to 20whp just from doing that. Maybe more depending on boost levels.
mikey
sd ftw
Old Sep 10, 2011 | 04:30 AM
babaz7's Avatar
Mikey
sorry but can you please tell me what a SD is?
and im running a stock ecu with flash will SD work with it?
