TurboXS H34 Bov
Old Jan 4, 2004 | 09:28 PM
GTVEVO's Avatar
TurboXS H34 Bov
Below are some pics that had been requested from a few people just for a visual of the AEM Intake and the TurboXS H34 bov. Feel free to post pics of your bov for examples as well.
Old Jan 4, 2004 | 09:30 PM
GTVEVO's Avatar
another
Old Jan 4, 2004 | 09:32 PM
MP5's Avatar
MP5
In Timeout
Is there any issues with the txs BOV? it looks completely recirc. is it? Nice clean engine bay
Old Jan 5, 2004 | 01:21 PM
GTVEVO's Avatar
It is completely recirc but with the intake it sounds very nice and loud. The only issue I have had with this bov is that becuase it is a bass and metal design you will hear a small whisle somtimes during the blow off. I have looked and tested everything and it seems to happen becuase it lays sideways instead of up and down. Isn't that big of deal but I do wish I could fix that. I can't complain though because it is a very good valve and holds boost very well with a nice look and fit.
Old Jan 5, 2004 | 03:33 PM
tpm17's Avatar
Just got my Turbo XS H34 today!! What a nice piece.... Lemme ask you... How many washers did you put in?? I'm debating on 3 or 4.... I'm running stock boost. Please respond with input..
Old Jan 5, 2004 | 05:30 PM
Bluesmaster's Avatar
I've tried 2,3, and 4. 4 seems better for my Evo. Superz (Gil) is running 4 on his Evo and is happy with it. I also hear a small whistle at times. It is annoying but it seems that every D/V except stock makes some kind of "different" noise. Turbo XS H34 holds boost very well, no stalling or idling problems. I'm running 19.5 lbs boost.
Old Jan 5, 2004 | 06:06 PM
tpm17's Avatar
Considering I'm running stock boost I was thinking I'd have better results with 3 washers... But I'll test between 3 and 4 to see what gives the best result. I'm glad I have this DV than the Frge because you don't have to remove the entire DV to tune it. I'm a fan of the wistling sound by the way.
Old Jan 5, 2004 | 06:44 PM
babyburner's Avatar
i got none, and i'm holding fine. i had some problems with more shims just ran jerky
Old Jan 5, 2004 | 07:02 PM
Stikilr's Avatar
In Timeout
im running with no washers as well and it runs great, i peak to 21 and only dropps to 20....
Old Jan 5, 2004 | 07:37 PM
GTVEVO's Avatar
Right on! I have tested every combo of washers and it is best to run none, everything operates much smoother. You can run 3 or 4 but in 4th and 5th at low boost I got flutter so I pulled them out and just didn't run any. This seemed to work the best for me.
Volunteer
Sep 21, 2005 08:56 PM
MitsuJoe
Aug 11, 2005 08:22 AM
quad3d@work
May 11, 2005 11:32 AM
EvilBlueEvo8
Nov 3, 2004 02:09 PM
Trail Slide
Feb 16, 2004 06:35 PM
