Walbro 400LPH intank pump ? Anyone got any info
Old Oct 6, 2011 | 11:34 AM
  #241
ChrisCarey's Avatar
Originally Posted by SyZyGy1394
I know its not clamped to the plastic, but is it resting on the plastic?
Correct, the clamp is simply making sure the pump won't slide down. I'll take another look at it and see if a cap of some sort would be possible.
Old Oct 6, 2011 | 11:49 AM
  #242
5LEEPERISAH23I's Avatar
after reading this thread for about an hour now ha.. i think this new Walbro is a great way to save money and wish it came out 2 months earlier. i mean on E85 this pump should be good for id say 600whp easy just a guess. n any pump gas car good forever..
$ 525 for double pumper
less then $150 for a walbro 400 ill take my chances
Old Oct 6, 2011 | 12:13 PM
  #243
tsidrift1's Avatar
Where you finding it for less than $150? lol
Old Oct 6, 2011 | 02:02 PM
  #244
Drifting Away's Avatar
You know the more people try to negate the need for a double pump the more they end up buying one in the end. (speaking from personal experience...)
Just sayin...
Old Oct 6, 2011 | 02:36 PM
  #245
RyuEvoIX's Avatar
Just sayin...
For individuals like myself who prefer to use a methanol/alcohol injection kit since E85 is not accessible for daily use, this pump would be the last pump that would ever need to be purchased. Regarding others who run E85, this pump will be sufficient to somewhere in the neighborhood of 650whp dynojet. There are certainly customers that will still need a double pumper setup beyond that, but I think it's safe enough to say that about 85% of Evo owners will never need a larger pump then this.
Old Oct 6, 2011 | 04:22 PM
  #246
DJAfterShok's Avatar
Just sayin...
I agree!
Do it once, do it right.
Your going to spend more money in the long run....
Old Oct 6, 2011 | 04:45 PM
  #247
ebay
Old Oct 7, 2011 | 08:17 AM
  #248
ChrisCarey's Avatar
Well I've got some bad news on the Evo X front, ran into fueling issues at about 1/4 tank this morning with a 7/32" siphon. Back to the drawing board I guess
Old Oct 7, 2011 | 09:23 AM
  #249
David Buschur's Avatar
NOW HEAR THIS!!! NOW HEAR THIS!!!
I WAS WRONG, THIS PUMP WILL GO IN THE EVO8-9 PUMP ASSEMBLY WITH SOME GRINDING/CUTTING!
I guess instead of just measuring I should have done some cutting on the assembly. The pump came in an hour or so ago and I started measuring again and then went to grinding.
You can grind or cut the bottom of the stock assembly away, like has been shown but keep in mind BE VERY VERY VERY CAREFUL NOT TO DAMAGE THE PORT THAT HOLDS THE FUEL PUMP PLUG (black thing with the oring/single black wire) on it. IF you damage that port you will ruin your assembly and the pump will NOT work.
The other thing, wiring is easy, much easier than has been discussed, so I get to have one up on the rest Order the wires that connect to the pump, release the plastic connector from the end of it and then simply put the OEM plug back on the end, it is a plug and play order, just release the pins and swap the plugs. It is a DIRECT plug in to the factory fuel pump assembly. All this tape and extra connectors are NOT needed, it's a PLUG IN.
I have the unit complete and together. I have made sure it does pump and the pump is QUIET!!
The best solution to holding it in the housing is a simple hose clamp around the top of it, it's not going to fall out. The factory fuel pump seal at the top of the pump works on this pump.
It's going to work, period. I am going to take this assembly I have here finished and send it out to have to flow tested, I want to see how much the factory filter and housing choke the flow down, we tested our double pumper that way and this will be the actual flow of the pump in the car and a direct comparison to our double pumpers.
Have a good day.
Old Oct 7, 2011 | 09:28 AM
  #250
tsidrift1's Avatar
NICE!!!
Didnt map do it so you could use the bigger filter sock the pumps comes with? Is that an issue still?
Looking forward to your results! I hope they arent disappointing. IM really wanting to get one of these.
  #251
B.J.@ToxicFab's Avatar
Have a good day.
hahahha! I loled at this!
  #252
evo 9 guy's Avatar
Have a good day.
Can't wait to see what it is.
Old Oct 7, 2011 | 09:42 AM
  #253
lude2evo's Avatar
Dave try and squeeze two on a double.
Old Oct 7, 2011 | 09:50 AM
  #254
metalsaber's Avatar
Interested to see what the flow data shows. I'm interested in adding this to get rid of the noisy 255 unit. It's much more noticeable when you have your back seat removed. haha
Old Oct 7, 2011 | 10:12 AM
  #255
REV.olution's Avatar
Official write up by myself
https://www.evolutionm.net/forums/ev...ml#post9656176
