Walbro 400LPH intank pump ? Anyone got any info
Old Sep 26, 2011 | 03:22 PM
  #46
EvoDan2004's Avatar
Originally Posted by evodan2004
David. Thanks for trying to see if it fits.
Does the aeromotive 340 fuel pump flow more then a modded walbro 255 fuel pump? I know ill never max out either in a double pumper but I ask because I think one of my walbros might be going and I want to replace them both with either the same pump or something better.
Pick me pick me
Old Sep 26, 2011 | 03:25 PM
  #47
izabran's Avatar
mine is coming in tomorrow... ill let you guys know by friday how it fits...
Old Sep 26, 2011 | 03:27 PM
  #48
RyuEvoIX's Avatar
Old Sep 26, 2011 | 03:31 PM
  #49
izabran's Avatar
ok i just read through lol... so i guess buschur answered this question... well i paid cheap for it so i guess ill see...
Old Sep 26, 2011 | 03:38 PM
  #50
RazorLab's Avatar
Originally Posted by deadmeat
I wonder how loud these ones are. My 255lph is a noisy bastard
It's a turbine style pump, liker aero/dw, etc so if anything, it will be quieter.
Old Sep 26, 2011 | 03:39 PM
  #51
RyuEvoIX's Avatar
If you decide you don't want to put the effort into make the pump work let me know. I will take it off your hands.
Old Sep 26, 2011 | 04:02 PM
  #52
David Buschur's Avatar
Yes, this pump flows more than a modded Walbro.
Old Sep 26, 2011 | 04:07 PM
  #53
EvoDan2004's Avatar
no silly. i know this one does. i was asking if the aeromotive stealth 340 fuel pump flows more then a modded walbro pump.
Old Sep 26, 2011 | 04:12 PM
  #54
danameisoj's Avatar
Originally Posted by bostonhatcher
My girlfriend tried telling me the same thing. She was wrong.
I guess im just immature but lmao... best post in this thread
Old Sep 26, 2011 | 04:14 PM
  #55
danameisoj's Avatar
would be nice to see what can be done with this pump , if at all anything .
Old Sep 26, 2011 | 04:17 PM
  #56
REV.olution's Avatar
Meh; I have a re-wired dw301 with adjustable fpr and cost me almost as much as a buschur double pumper. Seems like you can try all you want, to replicate the dp's success, but my advice is to bite the bullet and do it right the first time. Or else end up spending equal money for a sub-par setup.
Old Sep 26, 2011 | 05:06 PM
  #57
haha, OK sorry Dan. The pump you are questioning is failing left and right on E85, I don't know why you'd even consider it. Our DP kit with two modded pumps in it is more fuel than most will ever need.
Thanks REV.olution.
Old Sep 26, 2011 | 05:25 PM
  #58
bostonhatcher's Avatar
2 x 255 lph = 510 lph > 400 lph
$510lph < $400lph
/end thread
Old Sep 26, 2011 | 05:29 PM
  #59
milford's Avatar
every time a new fuel pump comes out and a thread is started or when a discussion on fuel pumps start, several people end up banned for short period of time. I can tell you this, the two variables that stay the same from thread to thread are the discussions about the topic, and the presence of a certain vendor.
Old Sep 26, 2011 | 05:52 PM
  #60
CO_VR4's Avatar
The pump length is correct, the diameter at the bottom is too large to fit. You can't just extend it because the tank is not deep enough, you wouldn't be able to install it. IF you cut the stock unit to make it fit you lose the filter, so then as I said, you end up building basically a double pumper set up with one pump in it and at that point you may as well use the double pumper as it flows more.
David,
Don't have the pump or the housing in my hands, like you do, so I'd appreciate your opinion on the following...
How much "longer" is the pump than the "standard" Walbro? If one were to CNC a spacer that would fit between the pump housing and the tank with a couple gaskets above and below, would that give enough space to lower the pump to clear the OEM pump housing limitations and still fit in the tank?
