MBC and Dynoflash question
Old Jan 6, 2004 | 11:31 AM
GottaGoFaster's Avatar
My mods were an AEM intake and Buschur Muffler Delete Pipe. I received my Dynoflash on 10/25/03. I was at 265whp with the Dynoflash, intake and Pipe. That 265whp was with about 1-1.5psi LESS boost due to the pipe.
I had a Hallman Evolution Pro RX MBC installed today. I did tons of runs to dial it it to hold at 19psi. My question is...should I have reset the ECU before I dialed it in...or...should I now reset my ECU now that it's dialed in...or...should I not bother resetting it at all?
Old Jan 6, 2004 | 11:41 AM
nastea's Avatar
probably both
Old Jan 6, 2004 | 01:00 PM
But I listed 3 options
...or we're you referring to resetting it before AND after the install?
Old Jan 6, 2004 | 01:25 PM
Alfriedesq's Avatar
Just send me your ecu and i'll give you the goods - or come by pruven for a re-tune - why play about ?
285 whp is in the works for you !
Old Jan 6, 2004 | 01:33 PM
Well it is over 5 hours from here to Pruven and I don't know if I can make that trip again I'm thinkin sendin in the ECU would save some time and headaches of that damn NJ/NY traffic
EDIT: What technical changes would you make to my already reflashed ECU if I would send it in to incorporate the new MBC?
Old Jan 6, 2004 | 01:34 PM
4-BNGR's Avatar
Just put the MBC on and you're good to go. I'm running about 20psi with the same mods you have - using the Buschur MBC (aka Hallman). 285awhp
You need the Buschur 2.5" DP to scratch at 300
Old Jan 6, 2004 | 01:40 PM
Alfriedesq's Avatar
Agreed - he can just put the MBC in with no problems
However i do have a flash more directed towards that use
The best of course is a custom retune
Anyway you like you'll be ok !
Old Jan 6, 2004 | 01:41 PM
4-BNGR's Avatar
Al-
What level of boost (max level) would you recommend running on just the "stage rev" tune?
Old Jan 6, 2004 | 01:56 PM
Just to clear up things, if I were to send my ECU in to you, you would not just reflash my ECU to one of your standard mail in flashes with boost control....You would make changes to my current map of 265whp to incorporate the new MBC (like change timing, A/Fs or something like that)....correct?
Old Jan 6, 2004 | 02:11 PM
BeenWaitin4Evo's Avatar
I'm interested in hearing the answer to this...
As of recent I've been considering throwing on the Boost guage, MBC setup to push and hold boost at 20psi (if possible).
After already getting a custom tune (MD), would you, AL, be able to incorporate the higher boost setting into a mail-in reflash?
Old Jan 6, 2004 | 03:09 PM
Alfriedesq's Avatar
Yes - we can help you to get it running very well on higher boost
However - nothing beats a custom tune - if you change something bihg like adding 3 psi your going to need a retune
However if you only go up like 1 psi you should still be fine
Old Jan 6, 2004 | 03:54 PM
Al, how can you answer my question...
Thanks man!!!
Old Jan 6, 2004 | 04:37 PM
By the way...here is a pic of my Hallman Evolution Pro Rx....no need to pull over to adjust boost
Old Jan 6, 2004 | 05:16 PM
MP5's Avatar
MP5
In Timeout
You arent scared of a passenger twist? You ought to put a $ on it
Old Jan 6, 2004 | 05:28 PM
Alfriedesq's Avatar
Thanks man!!!
Yes - I have your map - I would just extend the values down deeper into the load references - - not a guarantee that its perfect - but your low boost would remain as is
Best bet is to get over to see me when you have some time - - but not everyone can do that - thats why we do the through the mail tuning - so far everyone likes it but we do stay on the rich and safe side !
