What consist of the stroker kit
Old Oct 8, 2011 | 06:09 AM
eastxcelerate's Avatar
This might have been covered thousands of times. But this will be for searching purposes for others and just to get an idea on what really consist to build a stroker motor.
So to make it simple. If you were gonna put together your own stroker kit, what parts do you need?
On DSM using the stock block, you only need the 100mm crank (6 or 7 bolt, whatever block you'll use) and stroker pistons. The rods are same as the 2.0L. You will use the same bearings, water pump, oil pump, head gasket and gaskets, timing belts as 2.0L as well.
Is this similar to Evo's? Like I said if you were gonna put together your own. (Not buying the kit) that will be too easy
Thanks
Old Oct 13, 2011 | 06:41 PM
turbodoug's Avatar
It's the same deal as with the DSM... 100mm crank and stroker pistons.
Old Oct 17, 2011 | 01:43 AM
211Ratsbud's Avatar
And stock lenghth rod correct ?
Old Oct 17, 2011 | 04:10 PM
Piro Fyre's Avatar
Yes, stock 150mm rods. Evo 4G63s are the same except that the tranny is on the other side and compression is different.
Old Nov 6, 2011 | 01:58 AM
chaosfiend21's Avatar
is the 2.3l stroker based on a 2.0 or 2.4 block?
Old Nov 15, 2011 | 09:14 AM
It's 2.0l block with stroker 100mm crank, stock length rods, and stroker pistons. Feel free to correct me if I'm wrong.
Thanks for the input brothers
Old Nov 15, 2011 | 04:35 PM
D-Love23's Avatar
I'm Pretty Sure it's for the 2.0l
Old Nov 26, 2011 | 08:41 AM
J_scogs's Avatar
Yeah the 2.3 is a 4g63 block(2.0) with a 4g64 crank to my knowledge
Old Nov 26, 2011 | 01:28 PM
stayboost3d's Avatar
So you could just buy the crank, pistons, and rods, and build your own stroker kit? How much would it cost to piece together your own kit?
Old Nov 27, 2011 | 03:28 AM
galantman03's Avatar
^depends on how much power your looking to make. The stock 100mm crank is good, up to 700+ from what I've been told, but it's the rods and rod connecting bolts that you shouldn't cheap out on. if you want to make 800+ hp, purchase rods that support that much power, or talk to your shop for advice which will be clearancing and/or milling your head and block
Jacks Transmissions
Jacks Transmissions
Jan 4, 2013 12:26 PM
Defratos
Oct 1, 2009 02:45 PM
Strm Trpr
16
Aug 10, 2009 07:32 AM
Tonba
51
Feb 25, 2009 01:57 PM
Jrod@Buschur
95
Sep 3, 2007 11:42 AM
