breather valve?
Old Oct 14, 2011 | 04:25 AM
babaz7's Avatar
breather valve?
i am running my evo 8 without a breather valve connected to anything..is there any draw backs?
and is it somehow related to my car dying when i push in the clutch while i brake,or when i rev above 6000 rpms and back off the gas while standing still the rpm drops below 500 and dies sometimes?
Old Oct 14, 2011 | 09:52 AM
turbodoug's Avatar
The only draw back is that you're releasing emissions into the atmosphere. Not a concern to most of us.
Your other issue sounds like an airflow metering issue. Possible vacuum leak???
Old Oct 15, 2011 | 01:46 AM
babaz7's Avatar
maybe vaccum leak and also im running a full 3 inch intake on a stock MAF,is that contributing to the problem? do i have to rescale anyting?
Old Oct 15, 2011 | 02:06 AM
Sidnakit's Avatar
do you have a hks bov?
Old Oct 15, 2011 | 02:30 AM
babaz7's Avatar
no i have a tial bov...
Old Oct 15, 2011 | 03:51 AM
Pal215's Avatar
You should connect that opening to a hose and run it to your intake tube. That is how it is used on a stock setup. To lower oil blow-by gasses from getting into your intake use an oil catch can, then run it to the intake tube.
Old Oct 15, 2011 | 07:13 AM
babaz7's Avatar
im not worried about that!..i just want to know running a open breather valve without connecting to anything is that the issue i have?...which is when i rev the car standing still and let go off the gas it dies or comes below 500 rpms and kind of starts shaking the whole car and after a few seconds it idles perfect again?
if i get a breather filter will that help or that isnt connect to the problem i have?
Old Oct 15, 2011 | 07:41 AM
Evoixjohn's Avatar
I just got a k&n lilttle breather on mine! No problems
Old Oct 15, 2011 | 07:42 AM
Monkeysphere's Avatar
If you don't have a vacuum leak check your idle step. If your TB is out of adjustment it won't catch the revs properly as it drops down.
0to140in9
Sep 20, 2015 09:27 AM
Igaly1021
Feb 17, 2015 03:54 PM
Insanenoodle
Nov 28, 2014 07:16 PM
asu11
Jun 30, 2012 02:07 AM
FL_SilverEvo8
10
Dec 8, 2011 03:25 AM
