Compressor surge with Tial?
Old Nov 30, 2011 | 08:30 AM
griceiv's Avatar
Originally Posted by 240Z TwinTurbo
I recently switched from the factory IX BOV to the Tial QR BOV and now have the same issue. Prior to the swap I was not experiencing the part throttle surging so I would say that it is contributed to the BOV.
you are correct, the leaky stock BOV will eliminate surge at the expense of making less power. you can adjust the boost control to not drive the turbo into surge.
Old Nov 30, 2011 | 04:36 PM
240Z TwinTurbo's Avatar
Changed to the white spring and it did little, if anything, for the surge problem. It does release much easier for normal driving so I would recommend the white (-8psi) for those on stock cams/intake.
When I replaced the spring there is no way to add a bottom port. The underside of the diaphragm is essentially the dump path for the valve when it opens. In looking at the TurboSmart kit I think I can at least simulate to see if the concept of bleeding the top port works. If I unhook the vacuum line to the BOV it should open if the boost pressure on the valve face can overcome the spring force. I will probably test this theory tomorrow.
Old Dec 1, 2011 | 10:32 AM
griceiv's Avatar
if you've got a recirc bov or are running speed density, the -3psi (hot pink) spring is by far the best driveablity IMO.
groundzero1v
Dec 17, 2013 10:46 AM
blackdemon
26
Jan 20, 2008 01:44 AM
AlwaysinBoost
12
Nov 26, 2006 04:28 PM
gadsmevo
13
Jan 27, 2005 11:11 AM
Evoisdream
45
Jan 4, 2005 12:22 PM
