Evolution Evolved- English Racing presents the USDM Auto Evo
Old Dec 30, 2011 | 05:48 AM
  #151
Walt's Avatar
Originally Posted by 03whitegsr
Did you back up into the lights and launch from there or did you back way up and reload the drivetrain going forward? Can't tell you how many times I've seen people back up into the lights then break.
Pretty interesting project.
How well does this setup actually behave on the street? Sure, the idea of paddle shifters and clutchless shifting is cool, but autos and sequential manuals are nothing alike as far as engine braking and response goes.
Thanks, that makes a lot of sense, i didn't back up enough and reload the drivetrain. The lsd was probabley wound up..
Didn't want to thread jack, looking forward to seeing the results!
Old Dec 30, 2011 | 03:24 PM
  #152
JohnBradley's Avatar
Agreed, but one thought to consider for what its worth.
For drag racing the converters will not have a lockup, for road racing or street duty it will most likely get left in but I feel the kind of people that buy this have one thing on their mind, drag duty. With a lockup engaged it is more like a clutch than a standard auto.
Walt its hard for me to say without knowing more about what your overall setup is. Low profile tires with lots of grip, a little wheelhop, traction differential left to right and then some bad things could happen. In my experience I lost the center diff before I lost the front LSD.
Also, I got word this morning that Andrew has the car back together and we'll start testing after the new year. My trans and the White Evo are sitting in line that is all I really have for now.
Aaron
Old Dec 30, 2011 | 03:37 PM
  #153
wshihdnevo's Avatar
Aaron
Old Jan 1, 2012 | 08:37 PM
  #154
03whitegsr's Avatar
Aaron
Absolutely on the drag duty side of this. There were just a few posts eluding to this making an awesome street car setup for something more then drag racing.
I'm sure you can make it work for other forms of racing, but it seems like the manual would be the better choice unless you have no other option.
Very cool as far as expanding the EVO market to those that may not otherwise be able to drive a manual car.
Old Jan 1, 2012 | 09:43 PM
  #155
EvoDan2004's Avatar
can i ask a moron question?
how will this trans shift? meaning. do i put it in drive and just drive or do i put it in ''1'' and manually shift it to ''2'' and so on? i do not know what thats called. manual valve body? or is that something different? sorry for the really stupid question.
Old Jan 1, 2012 | 10:13 PM
  #156
mrfred's Avatar
There is a transmission control unit.
Old Jan 1, 2012 | 10:16 PM
  #157
EvoDan2004's Avatar
so it has its own ECU? does it need to be tired into the stock ECU or a standalone ''if thats what the car is using''?
Old Jan 1, 2012 | 10:42 PM
  #158
triple L's Avatar
wow the very first automatic evo ive herd of.... very interesting... keep it up ER!!
Old Jan 2, 2012 | 06:27 AM
  #159
RLLN247's Avatar
Will the drive shaft have to be changed or will our existing drive shaft work.
Old Jan 2, 2012 | 09:31 AM
  #160
Mikey@Spec-Ops's Avatar
Great work ER
Mikey
Old Jan 2, 2012 | 11:14 AM
  #161
hitman28's Avatar
manual windows, auto tranny
Old Jan 2, 2012 | 11:22 AM
  #162
domestickillaAR's Avatar
according to Aaron the electric windows are lighter then the cranks..i was asking him about this very subject n he was telling me about weight reduction n future plans for his car. i asked him if we was going to try to find some RS doors..
Old Jan 2, 2012 | 02:36 PM
  #163
David Buschur's Avatar
I can easily foresee this transmission, when it's worked out, being great for all types of racing/driving, not just drag racing. I like auto transmissions though, always have. I've never road raced with an auto. I think the biggest problem when using a typical auto trans in most applications is the ability for the trans to downshift when you don't actually want it to. For example, a typical auto trans on our dyno sucks. You want to dyno in 3rd gear but when you stab the gas it kicks down to 2nd or 1st even.
I just finished that '32 Ford project with the Evo engine in it. I put a TH400 trans in it, which is an auto 3 speed. I hated it. I took the trans back over to my trans guy, had him put a manual valve body in it. I absolutely LOVE the car now, the trans is fantastic! With the manual valve body you tell the car what gear to be in. You have to shift just like it is a manual but no clutch. If you stop and forget to downshift, when you take off you are going to take off in 3rd gear instead of 1st. If this option could be made for this project then you'd have a complete winner in my mind.
Old Jan 2, 2012 | 04:37 PM
  #164
94AWDcoupe's Avatar
Dave if you have a link to your ford build somewhere I would like to see and read about it. sounds like a cool car..
Old Jan 2, 2012 | 06:46 PM
  #165
kingjamEvo's Avatar
Aaron
Very interesting,i will be fallowing this closely...keep up the good work ER
