Evolution Evolved- English Racing presents the USDM Auto Evo
Old Jan 3, 2012 | 06:31 AM
  #166
David Buschur's Avatar
Originally Posted by 94AWDcoupe
Dave if you have a link to your ford build somewhere I would like to see and read about it. sounds like a cool car..
https://www.evolutionm.net/forums/ot...ern-power.html
Not a lot of pictures or updates on it as the interest here was low.
Old Jan 3, 2012 | 11:44 AM
  #167
Ang Wen Yan's Avatar
Originally Posted by triple L
wow the very first automatic evo ive herd of.... very interesting... keep it up ER!!
Well.......Mitsubishi themselves do make Automatic EVO and not just once
There is EVO VII GT-A(Model Year 2002),EVO IX Wagon GT-A(Model Year 2005) and EVO IX MR Wagon GT-A(Model Year 2006)
The spec on the auto gearbox is 5 AT with Fuzzy Logic
Here is how the interior look like:
Old Jan 3, 2012 | 11:46 AM
  #168
EvoDan2004's Avatar
we know they made an auto for the evo. but if you feed that trans any real power they seem to fail.
Old Jan 3, 2012 | 11:56 AM
  #169
The other problem is trying to get that trans here. We tried like hell and couldn't import all the stuff we needed.
Old Jan 3, 2012 | 12:19 PM
  #170
I believe it is possible to buy the front clip from Japan
Any lead on that??
Old Jan 3, 2012 | 12:41 PM
  #171
Scottr126's Avatar
Yah but if you break a part in that transmission good luck getting replacements..
Any lead on that??
Old Jan 3, 2012 | 01:20 PM
  #172
JohnBradley's Avatar
Originally Posted by hitman28
manual windows, auto tranny
Car is an RS.
Old Jan 3, 2012 | 01:39 PM
  #173
Originally Posted by evodan2004
so it has its own ECU? does it need to be tired into the stock ECU or a standalone ''if thats what the car is using''?
The TCU is a standalone unit that only requires a few inputs from whatever ECU the Evo is using. Andrew's is a stock computer, mine will be a stock computer for a bit and then something standalone, the White Evo is undecided, and the 4th test car is a standalone already.
Originally Posted by RLLN247
Will the drive shaft have to be changed or will our existing drive shaft work.
Existing driveshaft and front axles will work.
Old Jan 3, 2012 | 01:49 PM
  #174
HIS Motorsports's Avatar
Aaron, Do you need another Guinea Pig? I would be willing to test one on my personal daily drive that has 460hp on pump with stock motor and stock ecu!
Old Jan 4, 2012 | 03:15 PM
  #175
red97rum's Avatar
Nice! I was wondering when someone was going to give this a try
Old Jan 4, 2012 | 03:27 PM
  #176
old4g63's Avatar
I just finished that '32 Ford project with the Evo engine in it. I put a TH400 trans in it, which is an auto 3 speed. I hated it. I took the trans back over to my trans guy, had him put a manual valve body in it. I absolutely LOVE the car now, the trans is fantastic! With the manual valve body you tell the car what gear to be in. You have to shift just like it is a manual but no clutch. If you stop and forget to downshift, when you take off you are going to take off in 3rd gear instead of 1st. If this option could be made for this project then you'd have a complete winner in my mind.
I don't know how aaron's evo trans works. However for the DSM's you can make a harness that you give 12v and plug into the stock trans connector. You can then use the stock shifter to manually select first, second, or third. To get overdrive you need to close a switch but I think you get the point. No manual valve body work, just unplug stock TCU connection, plug in the harness, then dyno the car in "manual" mode.
Old Jan 5, 2012 | 06:14 PM
  #177
Right now we have one of those already. If we need to test more combos I will put out the call though. Right now we have the following-
2.0L VIII 11:1, stock turbo
2.0L IX, Red that made 430 as a manual and 520 on E85 (going back to E85)
2.3L VIII, 3586
2.4L IX, 3794
The last 2 are both over 800whp so thats really the test bed. Anything that makes less than it will survive if they do.
Unfortunately its not a DSM style, that would make things WAY SIMPLER.
Old Jan 5, 2012 | 06:17 PM
  #178
EvoDan2004's Avatar
Is there a manual valve body option? So the driver desides when to shift?
Old Jan 5, 2012 | 06:19 PM
  #179
Yes but not manual valvebody. You can still manually shift the car like normal if you want and we are working on making a sportronic shifter work from an outlander or lancer OZ. Still looks stock but give us "manual" mode. If nothing else a B&M can be adapted or the stock shifter assembly, which is fugly (stock to be clear), can be used for the same purpose.
Old Jan 5, 2012 | 10:36 PM
  #180
Bryant05TB's Avatar
I'm getting excited, I've been thinking about this everyday Great things are on the horizon for Evo's in all realms of racing.
-Bryant
