5.0 throttle bodies
I run a Boomba and love it. Never leaked for me. I have seen them test these to 70 psi and hold. They use loctite and pin the screws to make sure they don't come out. Reuses all stock sensors.
Could you inform me what is an issue with aluminum throttle plates?
Also, did you contact Boomba to try having them fix the issue with the cross threaded fittings?
Whoa! You need to really chuck something at that plate to make it break - metal just doesn't like to snap on its own lol.
Gotcha - Boomba has always been super helpful whenever I had an issue. Best part is they actually have listened to my feedback unlike some other companies I have dealt with in the past.
Best of luck to you in your search sir!
you need a progressive linkage to eliminate the drivability problems associated with a large throttle.
https://www.plazmaman.com/shop/index...tem&itemId=334
FS[Northeast]: Evo 8/9 oem throttle body W/O Sensors
yellowevo82
10
Mar 17, 2017 06:42 PM
