Help me make a shopping list for easy power from my stock IX
#31
I also read that tuning helps the vibration smooth out.
Can anyone confirm that?
thanks
#33
My evo 8 has lower and upper hardpipes,turbo back exhaust its a borla and looks fairly stock not overly loud either,255 walbro pump and an intake I made 358 and 332 spiking 22psi
#34
Tuning will smooth it out to an extent. Gsc s2 cams will have the aggressive idle if you want normal idle and more mid range power get the gsc s1
#35
FYI u wont pass ca emission test with a tune and mods... u will have ur tuner to upload ur stock basemap back into ur computer to pass... just to let u know that there is ups and downs... either stay stock and pass or sacrifice and go for power...
#36
EvoM Community Team
Where are you getting your information from?
The smart thing do to is to run https://www.evolutionm.net/forums/ec...hramod-v7.html and run a smog map that you switch to.
Not that I would do that or anything...
#37
Another buddy is running HKS 264/272 and you can tell by a stranger idle, but it doesn't sound loud or anything.
#38
I made 329/ 312 on crap cali 91 and 23 psi stock turbo, 100% stock motor and cams, stock o2 housing and injectors. My only mods are ETS 3.5'' FMIC, ETS 3'' intake, ETS LICP & UICP, ACT clutch and flywheel, walbro 255 fp, MBC, HKS carbon-ti, megan DP and test pipe. I'm adding a c.o.p, mona lisa manifold, and o2 housing because I'm trying to crack the 350-360 whp mark myself. Thats a pretty solid/standard list of parts for a stock turbo set up. The only thing I would change is the TBE because of the cops in CA. If I had to do it again I would go with the RRE stealth TBE
ModenaTwinTurbo
For Sale - Cars For Sale
31
Nov 6, 2013 05:04 PM
