quick going 2.4l question
Old Nov 6, 2011 | 05:20 PM
Gramdollar's Avatar
hey tried searching. i wanna go 2.4 (getting a 4g64 block and crank). i got all the internals figured out. but is there anything that's different like the water pump, or front case that i need to figured out? tried searching and couldn't find anything
thanks
Old Nov 6, 2011 | 06:37 PM
JohnBradley's Avatar
You need a modified 2.0L waterpump or a spacer. The oil pumps are the same, you need cam gears because of the deck height increase, and a good headgasket.
Aaron
Old Nov 7, 2011 | 10:52 AM
Gramdollar's Avatar
awesome thanks for the info. lol, looks like i'll go with the 2.3 =P
Old Nov 7, 2011 | 10:58 AM
Carloverx's Avatar
Aaron
Thread hijack: Aaron, when we alter the MIVEC cam gear, does the tune need to be adjusted at all?
Thanks!
Old Nov 7, 2011 | 04:35 PM
RockmanX's Avatar
why would you go with the 2.3 makes no sense those extra parts total are not over 300 and you still make out better and cheaper building a 2.4
Old Nov 7, 2011 | 05:58 PM
Dallas J's Avatar
Veteran: Army
Aaron
Why is the water pump spacer needed? Just curious since Im starting to research a bit of 2.4 goodness for my IX.
Also, I know cam gears are needed (OEM 2.4l) to compensate for the 6mm deck height difference but what is done for the mivec cam? Ive seen companies have lines to pull oil from an available spot (MAP) or drilling is needed for hydraulic pressure. I dont know if theirs a pressure difference using the available line vs drilling as far as pressure is concerned.
Old Nov 8, 2011 | 09:15 AM
We prefer to not use a spacer. We modify the waterpump instead, there is a thread around showing why The serpentine doesnt like offset from what we have found. The modification is needed because the 2.0L pump doesnt line up with the coolant passages. We tried the Evo 4 pump and it didnt work for us.
Aaron
Old Nov 8, 2011 | 10:19 AM
Silk's Avatar
Aaron, you recommend a cometic head gasket on 2.4 builds?
Old Nov 8, 2011 | 11:17 AM
Its what I use in my car and all of the high powered 2.4s we do. We dont use an off the shelf cometic nor the phuzion, we have one made for us.
MIVEC is closed loop.
Aaron
Old Nov 8, 2011 | 11:45 AM
RockmanX's Avatar
2.4s are very very fun motors for sure. Beyond worth the coin to get it built and dropped in
SS1000RR
Jul 10, 2015 06:58 AM
boostawd16
May 21, 2015 05:58 AM
malac0da13
Mar 29, 2012 09:50 PM
phrequenc
Mar 22, 2012 09:04 AM
evilempire76
Jul 24, 2007 11:41 PM
